Snow Sliding Off Of A Metal Roof? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2008, 04:49 PM   #1
Snow sliding off of a metal roof?
Hi Guys,
For a standing seam metal shed style roof, colored white and angled down to the north, how low of a slope will snow slide off of on its own?
Thanks in advance for your help.
Sincerely,
Solar Dave
Solar Dave is offline   Reply With Quote
Old 02-24-2008, 04:59 PM   #2
General Contractor
joasis's Avatar
Doesn't happen here often but anything above a 2/12 will slide with the right conditions. If you do a search for "ice dams" or blocks, you will find many types available if you have an issue...they can save a life.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 02-24-2008, 06:03 PM   #3
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
There is a limit on how low a pitch you can apply a standing seam roof.
I think 2/12 is the lowest.
But,to answer your ?,
I have installed the EDPM on 2/12 pitch,and yes the snow will slide off with the right conditions as joasis stated.
Seeing there is probably less resistance with the metal roof,I'm sure it's possible,even on the north side of a white roof.
oldfrt is offline   Reply With Quote
Old 02-24-2008, 06:04 PM   #4
Rewards Points: 150
Not fast enough if your in snow country,, Just after it sags and breaks the roof down is also common, Mostly depends on where you live. Florida,not so much ,,,Alaska 6/12,,,well maybe NOT. here in frozen midwest wouldnt build a metal roof under 4/12 and 5 or 6 /12 much prefered. IF you compare materials cost for the steeper,,,very little difference to go steeper,,,actually depending on dimensions maybe the same!! AND figuring more slope MAY save on under construction support costs!!
So quick answer,,,more info needed!! 3/12 and under,,,figure on problems and leaks!!
justdon is offline   Reply With Quote
not venting a metal roof penny0322 Roofing/Siding 6 03-25-2011 05:39 PM
Metal roof??? Tdoggy187 Roofing/Siding 51 03-04-2008 03:35 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
1928 metal roof rusting basilbiko Roofing/Siding 5 07-19-2006 11:57 AM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 09:40 AM
