"smooth" Side On Hardie Backer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 11:56 PM   #1
Rewards Points: 1,062
Question
"smooth" side on hardie backer
i am sort of frustrated a little that things like OSB and hardie backer do not come with a clear writing "this side up", instead one has to know... i know it's very rudimentary knowledge but it helps first timers.
so i saw online that THE SMOOTH SIDE goes up ... but what exactly is the smooth side? the side that has the relief with letters and a grid around is smoother when you touch the squares inside the grid but when you go across the whole surface, it feels coarser because you go over the letters. on the other side, that has no letters, the surface is coarser than the squares on the other side but is consistent...
so you can see my frustration. what gives, which side goes up? to avoid the smoothness confusion, i will give two choices:
A. the side with letters/relief
B. the side with nothing on it, i.e. the simple side
this illustration on this page implies A. but i just want to confirm:
http://www.jameshardie.com/homeowner...rterInch.shtml
Old 04-12-2011, 12:52 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
The 1/4" hardie backer will have the grid that may be used in placing tile or screws. The 1/2" will have a series of dots which may be helpful in placing screws. So you want to install them so these indicators are visible.
They go up as they are shown in the pic/link you provided.
Not an expert, but from what I've read, its not a big deal to install the wrong way. It won't cause a project to fail.
The Following User Says Thank You to Blondesense For This Useful Post:
amakarevic (04-12-2011)
Old 04-12-2011, 10:43 AM   #3
Rewards Points: 3,130
I don't know anything about Hardibacker, but Durock cement board has a rough side and a smooth side too. From what I have read, you put the smooth side up if you're using mastic, and the rough side up if you're using thinset mortar.
The Following User Says Thank You to md2lgyk For This Useful Post:
Maytag Side by side dannykapp Appliances 25 02-27-2011 09:25 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
GE Side by side water dispenser not working cfinchapex Appliances 3 09-19-2009 10:39 AM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 05:40 PM
Cathedral ceiling without sofit vent on one side ChrisO Roofing/Siding 3 01-31-2007 10:51 AM
