Smoke Coming Out Of Fireplace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2010, 12:33 PM   #1
Smoke coming out of fireplace
I've got a majestic fireplace/flu installed, but am noticing a considerable smoke smell in the house/cabin. A flashlight beam above the fireplace did show wafting smoke coming out the front face of the fireplace.
Checked the flu, and it was wide open.
Any ideas?
HHac8014 is offline   Reply With Quote
Old 01-01-2010, 12:57 PM   #2
ccarlisle's Avatar
Is this all the time or just occasionally?
Is it cold outside? where are you? dd you 'warm up the flue' before lighting the fire?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 01-01-2010, 01:15 PM   #3
is this new construction with all masonry or insert. sometimes what is called the smoke shelf inside the firebox is not deep/tall enough and any change in outside temp or wind will make the smoke roll to the inside. I know of no fix for this. Has this always been?
Old 01-02-2010, 06:04 AM   #4
Rewards Points: 582
There are a number of reasons that this could be happening.
1. Air starvation. If opening a door or window helps, this could be one of the causes.
2. The size of the flue in relation to the fireplace opening.
3. The design of the throat and the flue.
4. If the lining is leaking cold air into it.
5. If the flue terminates where wind could cause a downdraught.
Ideally you need an on site inspection. You don't want any leakage of carbon monoxide, even slight ones.
stuart45 is offline   Reply With Quote
Old 01-02-2010, 06:13 AM   #5
Chimney at least 2' above nearest house roofline.
Old 01-02-2010, 06:32 AM   #6
DIY staff
Rewards Points: 7,174
Stewart45 gave you the things to look for.
Often the problem is caused by the furnace/return air causing negative air pressure in the room.
Do you have forced air heating? Does the problem occur only when the furnace is on?
Keep us posted--You might have to call in a pro if the solution is not obvious.--MIKE--
Old 01-02-2010, 12:46 PM   #7
Try burning kindling and light wood at first to warm up the flue, and put the heavy stuff on the side to dry out. There needs to a hot updraft in order for the smoke to be pulled out(this includes air getting in).
You might want to compare the dimensions to those standardised ones, to see if it is built correctly.
I'd also recommend a $60 CO/Gas alarm, which is much cheaper than the alternative.
Stillwerkin is offline   Reply With Quote
Old 01-03-2010, 04:38 PM   #8
Licensed Engineer
Rewards Points: 175
Opening appears far too tall!
Just based on the photo, where it appears the top of the opening is in line with the height of the wall switches. Fireplaces have very specific dimensional requirements which are mandatory for proper (i.e. smoke free)operation.
MI-Roger is offline   Reply With Quote
How do you stop cigarette smoke coming through walls? ACTed General DIY Discussions 6 08-16-2011 03:14 PM
Smoke or steam coming from grass Holt Landscaping & Lawn Care 0 11-05-2009 10:53 AM
Cigarette smoke coming through return? diyGK HVAC 5 10-29-2009 11:19 AM
help -black smoke coming out of chimney after furnace service wombosi HVAC 9 11-14-2008 04:54 PM
Power cord coming out of my propane fireplace NettyPoo Electrical 2 12-03-2007 07:31 PM
