Smell Under Sink - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 03:48 PM   #1
Smell under sink
I have a mysterious smell coming out of the cabinet under the kitchen sink. I pulled everything out and thouroughly cleaned it, and then searched under the kick plate for dead mouse, then under the trailer, then under the subfloor between the joists. The trailer is only a year old, and the smell is somewhere between mouldy rags/dead mouse. I have even taken the pipes apart and cleaned them. I'm stumped! Anyone ever expirienced this?
carpfarmer is offline   Reply With Quote
Old 11-09-2011, 10:22 PM   #2
Rewards Points: 1,092
Carp: Never mind. I just re-read your post, and you've already looked at the floor insulation. Hmmm.
Old 11-09-2011, 10:52 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
FEMA trailer?
Old 11-09-2011, 11:30 PM   #4
Rewards Points: 502
do you have an air inlet valve as apposed to a normal vent for that sink?
I was planning an air inlet valve on my sink and realized a drop or 2 of the PVC cement got somewhere and ruined it to where it was letting air escape and would have basically acted like a hole in the pipe, letting sewer gasses in.
forresth is offline   Reply With Quote
Old 11-10-2011, 10:45 AM   #5
Yes I have an air inlet valve which I was able to remove and inspect. It doesn't have a filter, but the smell is not a sewer smell. It's also really confined to the one cabinet. If you put your head into either of the adjacent cabinets there is no immediate smell.
Old 11-10-2011, 11:21 AM   #6
Rewards Points: 502
Filter? AIVs are basically a spring loaded valve that permits air movement in one direction, but not the other.
A slight weeping of air would have a different "flavor" than an open pipe. I'd probably replace the AIV with a new one I tested first before ripping apart walls and cabinets looking for other causes. They aren't that expensive.
It could be a glue or insulation smell from off-gassing. It really could be just about anything.
Maybe bring a friend over with a strong sense of smell to investigate. The smell may be much more pervasive than you think. When you are constantly exposed to odors, you physically can no longer smell them. My wife gave up her pet ferrets that she had for years and years after she had them out of the house for a couple weeks during a remodel because she realized just how bad they stunk when she took them back. I can't say I miss them at all.
Why does my Kitchen Sink Smell? Syz Plumbing 10 10-30-2011 11:13 PM
Mysterious Smell Under Kitchen Sink jimmycrackcode General DIY Discussions 6 10-22-2011 12:43 AM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 03:39 PM
Sewer smell from under sink and adjoining closet, but not from drains? aaronb9 Plumbing 37 09-27-2009 07:42 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 12:01 PM
