Smartside 8in Lap - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 01:37 AM   #1
Smartside 8in lap
I am going to try my hand at installing the 8 inch lap siding.
The siding on the house is hardboard panels. I pulled off the siding along the side of the attached garage. I found that it has 1/2 celotex foam, no OSB/plywood sheathing.
The foam board end above the sill plate and is flush with the sill plate. How do I detail the the bottom edge at the connection of the block foundation and the sill plate.
I will be installing Tyvek over the foam.
With the 8in lap I was planning on a 7in reveal, actual 6 7/8.
Any suggestions are welcome.
Roberthr is offline   Reply With Quote
Old 10-18-2012, 01:52 AM   #2
Rewards Points: 13,260
Really could use a picture.
The sheathing was suppost to run past the sill plate by at least 1" so it could be air sealed.
There was also suppost to be plywood or OSB in all the outside corners for shear strength.
blind nailing 12'' lp smartside pwa Building & Construction 11 08-28-2012 10:32 AM
waterproof back of smartside siding? pwa Painting 6 07-27-2012 08:15 PM
Installing felt under LP smartside paneling cortell Building & Construction 1 07-24-2011 10:23 PM
LP Smartside Lap Siding - Nailing Question? canyonbc Carpentry 3 01-18-2010 02:26 PM
Strength of 'SmartSide' raykos Building & Construction 1 09-18-2009 08:51 AM
