Small Retaining Wall/guard With 4x4 - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 12:43 PM   #1
Rewards Points: 1,062
Question
small retaining wall/guard with 4x4
i need to have a small retaining guard maybe 10" high that would hold dirt on one side. i was gonna stack 3 4x4 one atop another but was wondering:
1. what do i use to fasted the 4x4 to one another ?
2. do i need to have a concrete footing under the first one in the ground or can i just plant it into the dirt ?
thanks
Old 08-22-2010, 01:08 PM   #2
Civil Engineer
Rewards Points: 4,944
You can use wood, however it should be pressure treated. You can nail the boards together using galvanized spikes. I would recommend using segmental concrete blocks, easier to work with compared with wood, and they do not rot. Price should be comparable. These blocks are available in any big box store, sold under a wide variety of names, and made by a lot of different companies. And you don't need a footing for wood or segmental block, not for a 10 inch high wall anyway.
Daniel Holzman is online now   Reply With Quote
Old 08-22-2010, 01:23 PM   #3
you mean cinder blocks ?
Old 08-23-2010, 07:21 AM   #4
Rewards Points: 4,800
they'll be out in front OR near the landscaping/plants area,,, at least most of ours have a display of 'em,,, they're cast of concrete & dusted w/various colors - suitable for segmented retaining walls, driveways, patios,m,, no one uses ' cinder blocks ' anymore - they're all extruded concrete block to my knowledge
Old 08-23-2010, 10:51 AM   #5
if you decide to use the 4X4s or 6X6s, make sure you run a few perpendicular to the face of your wall. these will extend way back into the bank and prevent the wall from otherwise just falling out. i would have at least two of these on each course.
if you ever look at a 6X6 retaining wall, you'll notice the square end grain pieces - usually arranged in some sort of decorative patter.
same goes for concrete block or anything: you can't simply stack up a wall like 8" wide and expect to remain standing. for 10" high, MAYBE.
but you need some long stuff tying back into the bank.
also, make sure you "batter" the face, or slightly lean it back toward the bank out of plumb.
wombosi is offline   Reply With Quote
Old 08-23-2010, 12:08 PM   #6
Civil Engineer
Segmental block retaining walls are specifically designed so you can stack the blocks on top of each other, up to about 4 feet tall, with no tiebacks. The blocks have index pins that create the proper batter. In order for them to work, you need properly draining backfill, usually specified as crushed stone or coarse sand. Each manufacturer has different textures and sizes available, and of course the installation instructions vary. It is essential that you read, understand and follow manufacturers instructions, but if you do the blocks are going to work well, they are easy to install, and they will last a really long time. In my book, they beat PT lumber hands down.
Old 08-23-2010, 01:10 PM   #7
concretemasonry's Avatar
Rewards Points: 2,652
Not all SRW walls require pins for walls that low. Usually pins are not required for such a low wall and tie backs are not necessary.
There a 4 major brands that are licensed internationally and in the U.S. The block usually have either a molded lip for shear resistance or even geo-grid (a grid to tie is back into the soil) if the wall is over 4' or 5' high.
Do NOT use a concrete footing for segmental wall even if is 40' high. If you know the brand/type go to the website for ideas and installation instructions. The manufacturers might give you a link.
Dick
concretemasonry is online now   Reply With Quote
Small, very small bathroom exhaust fan stubits HVAC 3 04-06-2010 01:52 PM
In The Process Of Building My Very First Small Retaining Wall ricksample Landscaping & Lawn Care 3 03-19-2010 09:19 PM
Big HVAC Guy vs Small HVAC Guy flysndoc HVAC 4 09-20-2008 11:06 AM
small electric heater recommendation bdog1234 Electrical 9 02-24-2008 02:12 PM
Curved Small Stage jalaux Carpentry 1 07-09-2006 09:57 PM
