08-19-2012, 03:13 PM
#16
Civil Engineer
small garage stairs
Based on personal experience, it is more difficult than you might think to cut perfect stringers. The idea of box steps is very appealing, if I had it to do over, that is what I would do with my deck steps. Simpson and others make very easy to use hangers to attach the treads to the box stringers, bombproof, code compliant, easy to install. There was a post suggesting concrete block steps, which might work very well in your case. Concrete block is very cost competitive, relatively easy to install, worth considering.
08-20-2012, 04:06 PM
#17
small garage stairs
Should I use tapcons or concrete bolts when I secure the top riser to the concrete block underneath the threshold?
08-20-2012, 04:44 PM
#18
small garage stairs
Tapcons are fine.
If my advise helped you hit "Thanks" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
09-07-2012, 02:52 AM
#19
small garage stairs
I haven't started building the stairs, but I will soon.
I am assuming you all suggest tapcons for attaching the header to the wall because of the fact that the foundation is a concrete block construction.
Don't you think those expansion bolts are stronger than tapcons?
I am pretty sure the concrete block wall was filled.
09-07-2012, 08:50 AM
#20
AHH, SPANS!!!
small garage stairs
Originally Posted by gta
It is about 17.25 inches from the concrete to the threshold.
[quote=I haven't started building the stairs, but I will soon.
I am pretty sure the concrete block wall was filled.[/quote]
3- 5.5" or 6" (finished height) steps would fit your situation well and tap cons can be used for the riser if it sits down onto the top step but expansion bolts would be much stronger and recommended, especially for the structural part of the stair to block attachment.
Reason: oops
09-07-2012, 09:02 AM
#21
AHH, SPANS!!!
small garage stairs
09-07-2012, 03:02 PM
#22
small garage stairs
for a 5-1/2" to 6" riser you should make the treads about 11-1/4" minimum. "Rule of Thumb" for stairs 1 riser + 1 tread = 17" to 18" (old builder's tale) the shallower the riser the wider the tread.
Gary
"You get what you pay for, and sometimes free costs more!"
09-07-2012, 09:39 PM
#23
JOATMON
small garage stairs
2x12? In my addition, my stringers are 2x14....
Anyway....
Since we are talking only a few steps, why not platform? Instead of worrying about stringers...just build it all the way to the ground. with PT as the bottom plate.....
I personally think the 'sides' on those stairs make for a trip hazard. I would prefer an open tread.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
09-23-2012, 12:56 AM
#24
small garage stairs
Well, looks like I'll be cutting box steps.
I cut my first stringer and everything was perfect. The measurements, the materials except for one thing.
The freakin circular saw I had was not square even though I checked it with a square prior to use.
Apparently something happened during the cut that caused it to go out of square. I'm not really sure. Maybe I pressed down on the work piece too hard?
Anyway the first stringer had beveled cuts along the rise and runs. Not acceptable imho. Good thing I only cut one stringer.
The idea of a box stair is now very appealing. I will also be getting a new saw. Perhaps a makita not a cheapo skil.
09-23-2012, 10:14 AM
#25
AHH, SPANS!!!
small garage stairs
because you will be building landing type steps consider 16" steps and my info in the other post was incorrect, you will need 2 steps built not three. 2 - 6" finished height steps would divide evenly into your 18" height and as GBrackins mentioned, the larger tread steps will accommodate the smaller height risers and you will appreciate the extra tread when stepping down from the doorway onto them. The makita saw is a very balanced saw and I have liked using them , never owned one though.
09-26-2012, 03:26 PM
#26
small garage stairs
Im still in the process of cutting out my stairs, but I have a question.
Even with the makita, the cut is not perfectly square. Any reasons why?
It is better than the skil, but there is still a slight bevel. I don't plow through the material too fast and I use a straight edge guide.
I don't know if this makes sense but, the two sides of the blade that are closest to the base plate are square, but when I make a cut, the top side of the cut is indeed square but the bottom cut has a slight bevel relative to the top cut.
The blade could be flexing? I don't know.
09-26-2012, 03:33 PM
#27
small garage stairs
have your confirmed the 90-degree angle with a speed square?
Gary
09-26-2012, 06:59 PM
#28
Moderator
small garage stairs
Sounds like time for a new blade.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
09-26-2012, 08:15 PM
#29
small garage stairs
Yes. I placed a square up to the blade and it is 90 degrees. For some reason, during the cut, it goes out of square.
I used the blade that came with the saw. It is a makita 24T framing blade. It is kind of thin. Maybe that's the problem?
09-26-2012, 09:20 PM
#30
small garage stairs
could be .....
I've seen guys pushing the blade into the wood (pushing down from the side while operating the saw) and the blade might bend a little. I usually use my square as a guide to run the saw against. other than that your guess is as good as mine .....
Gary
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
