Old 01-17-2011, 10:54 PM   #1
Is small gap at base ofblock wall supposed to be there?
I have a long 4' tall block wall in my house. At the base is a small gap between all of the blocks at the bottom of the wall. If I stick a screwdriver inbetween them it just goes down into the dirt. Are these there for a reason? During the last major rainstorm it seems that water was coming inside of my building through these holes. Would it be ok to fill them with concrete and then seal the wall with drylok?
Picture: https://mail.google.com/mail/?ui=2&i...disp=inline&zw
tunaman is offline   Reply With Quote
Old 01-18-2011, 12:06 AM   #2
Moderator
Sorry, I could not see it, try this "How to post a picture" from our "How to guides"; How to attach a photo to a post
Gary
Clothes taking longer to dry?
Old 01-18-2011, 04:41 AM   #3
Were it my place, I would address the outside water issue asap. Something is not right outside; search here for similar posts/solutions. There are several things you can do to maybe eliminate the problem, then leave the holes there for the voles to come and go.
Old 01-18-2011, 07:23 AM   #4
can't see them either but here's a guess,,, that ' slot ' was where the contractor used isolation jnt which has since either been removed OR disintegrated for some reason,,, filling the slot will only force the wtr to seek relief somewhere else,,, i'd address the outside water issue, too
^5's, klinger !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 01-18-2011, 10:59 AM   #5
Ok, thanks for the link. Here we go.
Is small gap at base ofblock wall supposed to be there?-img00099-20110117-1946.jpg
Replacing 240V Wall Heater with 240V Base Board Heater jasoncw Electrical 7 11-26-2010 11:39 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Wall Cabinets as Base bjlffire Carpentry 5 01-11-2010 11:34 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
