Old 11-06-2009, 02:41 PM   #1
Default Small Foundation Hole?
I have a small V shaped hole in the foundation corner of my garage. It's pretty big for a mouse, but not big enough to put my hand through.
Actually it might have been an amature water or gas line fitting at one time, but now it's empty and I need to patch it.
It's a V cut into the foundation rim (there is a 4" cement rim around the garage floor) and above the V is studs. I can see daylight, so the opposite side is probably at or near ground level, but I haven't been to the outside due to snow and mud.
What is a good way to fix this? Temporary and permanent solutions welcome. I'll be finishing the garage in the future, but not anytime soon.
jage is offline   Reply With Quote
Old 11-06-2009, 04:24 PM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
Pack it with rock from both sides & then cement over it
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
More On This Topic
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
Rodents such as mice and rats, are most likely to enter a building as the weather turns colder and frost starts. Their outdoor habitats may not protect them from the weather and their food source runs low as well. They are attracted to the heat within a... Read More »
Disney at Garage sales. How many of us love Micky Mouse? I do! But guess what? This is not an antique. I could buy this at my local supermarket last year. It's not worth anything. This is a garage sale loser. You think that anytime you see a Disney... Read More »
How to Fix a Doorknob Hole
How to Fix a Doorknob Hole by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip I will be showing the procedure for mudding a hole cause by a doorknob. If you have a area on your wall where a doorknob came back and poke a hole in your wall a easy fix is to mud over that... Read More »
We're back in our room and now we've got, mostly finished, drywall and a coat of primer paint and we chose this orange primer color because we're going to come over it with a caramel color. Drywall, mud, tape, sanding and a coat of primer always over... Read More »
Hole in Foundation cougar01 Building & Construction 2 06-06-2009 09:59 AM
freezer leaking into fridge - cannot locate drain hole pro_DIYer Appliances 5 01-01-2009 01:08 AM
Filling in large openings in concrete foundation shtoink Building & Construction 10 12-04-2008 06:03 PM
No Mud Sill - Rim & Joist directly on Conc. Foundation GreenTrends Building & Construction 9 03-16-2008 11:52 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 12:16 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
