Small Deck Supports - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-20-2010, 06:30 AM   #1
Small Deck Supports
I'm looking at putting a second floor deck off my bedroom. 6' deep and 12' long. Would it be possible to support the deck rim with (2) diagonal posts tied back at 45 degrees or more back to the house wall instead of going down to the ground. The supports could go out 4' to 5' and let the last 1' to 2 feet cantilever. This is new construction so the diagonal supports and the attachment to the wall can be configured and designed correctly without dealing with an existing structure.
THEOALLEN is offline   Reply With Quote
Old 04-20-2010, 09:18 AM   #2
You would probably need an engineer to run the design numbers & see if it works
6x12 is a fairly decent size to support
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
Best small power saw for deck & fence construction Gibbyplease Carpentry 7 01-12-2010 05:53 AM
small area of rotten wood on deck hohadcr Carpentry 1 09-10-2009 04:11 PM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 07:03 PM
deck questions robphelan Carpentry 6 06-25-2006 06:42 PM
