Small Cracks In PT Sole Plates On Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2008, 02:54 PM   #1
Rewards Points: 1,062
Question
small cracks in PT sole plates on concrete
i was shooting a PT 2x4 sole plate into concrete the other day with my power-actuated gun (love that thing even though it requires cleaning and lubing).
when shooting an end nail some 2" from the end of the stick, the stick split but very mildly to the point of not looking it would split any further. i placed a stud perpendicular over the crack and it all looks solid.
is this tolerable or even small cracks in sole plates can pose structural risk ? this is non-bearing construction just to hand drywall and such, the support is done by brick walls.
Old 07-22-2008, 05:09 PM   #2
Drywall contractor
Rewards Points: 1,070
Won't hurt anything. Pre-drill a hole close to the ends to prevent the splitting of you're concerned. Just a bit smaller than the pin you're shooting and it should do the trick.
bjbatlanta is offline   Reply With Quote
Old 07-22-2008, 05:11 PM   #3
Exclamation
thanks !
Old 07-22-2008, 05:16 PM   #4
Registered User
Termite's Avatar
As long as the wood is intact, it would not worry me if there's a crack.
Old 07-22-2008, 05:57 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As Kct stated, don't worry too much about it, since it is just a partition wall, not load bearing. Be aware that the powder actuated fasteners will split smaller sections of walls, or, if you fire a pin in at the end of a plate. That means that you should always fire pins in away from the ends, and use construction adhesives for smaller sections of sole plates.
- Build Well -
Old 07-22-2008, 06:17 PM   #6
sorry, my statement was ambiguous. the crack is in the sole plate, not the concrete but a very small one. i was nailing maybe 2-3' away from the end.
Old 07-22-2008, 06:19 PM   #7
which would be what ? i do have candidates for that, since i need to fasten some sole plates like 5' long.
Old 07-22-2008, 06:36 PM   #8
ccarlisle's Avatar
You said 2" from the end and you got a crack...then you said 2-3' from the end. So which one is it?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 07-22-2008, 06:43 PM   #9
2 inches, i am sorry. i come from the metric system and this is all confusing to me.
Old 07-22-2008, 06:46 PM   #10
Under about 10".
- Build Well -
Old 07-22-2008, 06:50 PM   #11
Drywall contractor
Again, even for small 4"-6" plates, (for example a return wall for a door) drill your plate before you shoot it. As WB said use construction adhesive too. Use a lighter load so the pin doesn't sink all the way. Allow the glue to cure for a day, shoot again with a light load to set the pin. The glue actually helps keep the plate from splitting as does drilling it.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
Old 07-22-2008, 06:57 PM   #12
Question
Under about 10".
my question was which type of adhesive would you use for this kind of application (lumber-to-concrete) ?
thanks,
- a -
Old 07-22-2008, 08:53 PM   #13
Rewards Points: 392
thanks,
- a -
Polyurethane adheasives work really well for bonding anything to just about anything. the only downside is when you open a tube you have to use it all as it has poor shelf life, even when unopened.
rustyjames is offline   Reply With Quote
Old 07-22-2008, 10:56 PM   #14
and, let me guess, they make containers on average much larger than what a single average application requires ... same thing with Tuff-Stuff. once you crack that open, you can throw it away after 15 min. they don't make smaller cans.
Old 07-23-2008, 02:48 PM   #15
Drywall contractor
Yes, but a small tube of Liquid Nails or similar product is maybe $3.00 and has many uses. Tape up the end of the tube tightly and you'd be surprised how long it will last. Use the remainder on your studs when you hang the drywall. Drywall is best glued AND nailed or screwed.
Tile on concrete floor....with 1/8th inch cracks.. tigerbalm2424 Flooring 23 06-21-2008 10:01 PM
How to level small patch of cured concrete? RDS General DIY Discussions 11 06-05-2008 01:41 PM
power-actuated nail size for sole plates amakarevic Building & Construction 4 06-03-2008 02:12 PM
correcting slightly uneven small concrete surface amakarevic Building & Construction 5 01-16-2008 08:38 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
