Small Concrete Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2010, 11:15 AM   #1
Small Concrete Slab
I am in the process of pouring a small 8' x 8' slab in my yard as a footing for a shed. The shed will be used for an air compressor, lawn mower, and other lawn care equipment. Should I put down a vapor barrier? Also, how much of a layer of gravel should there be under the slab?
mopowers is offline   Reply With Quote
Old 06-03-2010, 01:11 PM   #2
joed's Avatar
Rewards Points: 13,718
No vapour barrier. 4-6" of gravel for drainage.
Unlevel Concrete Slab for Shed Osiris Building & Construction 4 07-10-2009 07:42 AM
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 02:32 PM
Cork or engineered wood over concrete slab w/ Radiant heat, HELP! newdyier Flooring 9 11-04-2008 04:11 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
