Old 10-30-2009, 02:27 AM   #1
Default Small Concret Mixer
I'm looking into purchasing a small concret mixer for pouring a concrete footing for a small wall and some other stuff. I see there are many choices around. However there are many that cost a lot more than others (Multiquip, Imer etc) as opposed to ones by Harborfreight and Home Depot (Husky). These are all around the 3 - 4 cu ft size.
My question is - is it worth paying more for a better brand or would the cheaper ones work just as well.
blue_can is offline   Reply With Quote
Old 10-30-2009, 04:38 AM   #2
the cheap ones are fine if you only need them for a job or two. Professional use where you mix concrete daily will kill these cheap ones very quickly.
Bob Mariani is online now   Reply With Quote
Old 10-30-2009, 08:02 AM   #3
Default What about "U-Cart" concrete?
If you only have a couple small jobs to do, purchasing these small quantities of concrete from a yard that rents you a small trailer with the concrete is another alternative.
Assuming you have a tow vehicle, and that you can't foresee using the mixer many times in the future.
My Dad's family owned a small cement mixer for doing small jobs. The problem was always discovering who in the family had it stored in their yard when Dad needed it for a home improvement job, and hoping it didn't need too much repair or chipping out prior to use. Owning a small mixer may guarantee you a whole new crop of "friends", some who may not take adequate care of your tool.
I know, my boss call me a cynical old SOB. But there can be a down side to owning specialty tools. Just be aware.............
MI-Roger is offline   Reply With Quote
Old 10-30-2009, 12:39 PM   #4
LOL. It is always better to be the borrower of someone elses rarely used, expensive, specialized tool that takes a lot of space to store instead of being the owner who is always lending it out. Can you find someone who knows someone who's relative has a neighbor with one?
Maybe work out a borrowing trade? I managed to trade the use of my drywall lift for the use of a friend of a friend's roofing coil nailer.
Old 10-30-2009, 08:52 PM   #5
I got one of the small Kushlan wheelbarrow mixers at Northern Tool. Unfortunately, the style I bought had turning fins molded into the drum - they did not work well. Be sure to get one that has metal blades for turning the mix.
walkman is offline   Reply With Quote
Old 10-31-2009, 12:59 AM   #6
Ha Ha - good point about people borrowing tools. Actually it's not been too bad given I have a huge tool collection. Among my tools I have a 20 ton hydraulic press, a MIG welder and a whole bunch of metalworking tools, plumbing tools, tools to work on natural gas lines, electrical tools, masonry and drywall tools etc. I also have a comprehensive collection of stone fabrication tools as I fabricate my own tops out of granite, marble etc. I do have people borrowing tools but they usually bring it right back.
I do have quite a few cheap tools such as Harborfreight and some of them are surprisingly good value for money especially if you don’t use them to make a living. I bought their mid-size demolition hammer to dig up my yard for a new patio (which is what the concrete mixer is for) since around here we have hard clay soil which is full of large rocks and boulders. It cannot be dug by hand. I dug out about 10 cu yds of material and it worked really well.
The reason about considering a good concrete mixer is due to the fact I cannot afford to have it breakdown during a pour since the concrete will set within a finite amount of time. If there were no time limit like this I would be quite happy to chance it with a cheap tool.
I was looking at this one as a possibility – do you guys think this would be a good buy. I like the fact it can be used as a wheelbarrow but also comes with a stand of you want to use it from a fixed location and use a wheelbarrow to move the concrete.
http://www.contractorsdirect.com/Con...iquip-Mix-N-Go
Old 10-31-2009, 01:27 AM   #7
I rented one similar from Home Depot to what is at the provided URL - worked well. It was easy to handle - low height to fill, and dump.
Don't remember what the cost for a weekend was, but it was not a whole lot. I was thinking of buying one of the inexpensive ones to - then did the rental. The rental worked well.
Old 10-31-2009, 08:37 AM   #8
I have many sizes. The small one like mentioned here is never used. My guys feel they can mix a larger batch by hand much faster, and these make too little batches to be worth the effort.
Old 10-31-2009, 11:23 AM   #9
Wolf
For small, infrequent jobs I have used the Cement Solutions bag (http://thecementsolution.com/) and would not have believed they could work so well. The first job I did was a large footing in my finished basement that required thirteen 80# bags of concrete. No problem... each bag mixed in under 3 minutes with NO DUST in the home. The only thing I would add to the instruction on their website is to use a pair of rubber gloves to give a final mix to the concrete once it has been mixed per instructions. I'm a DIY'er with no financial connection to the product.
ralphfravel is offline   Reply With Quote
Old 10-31-2009, 12:05 PM   #10
This is one of those 'duh, why didn't I think of that' items. Most excellent.
Old 10-31-2009, 04:29 PM   #11
Full-Time Half-Wit
Mort's Avatar
If its a yard or so, go to United Rentals and tow one of those 1 yard mixers home. They had $120 per yard on their reader board for a long while, and that's not bad for the situation.
If its more than a yard, order it from your local concrete company. That is, assuming you can get a concrete truck where you want it.
Cement is a powder.
When combined with rocks, water, and sand, it becomes
Concrete.
Mort is offline   Reply With Quote
Old 11-02-2009, 01:05 AM   #12
Thanks for the suggestions everyone - a few options to think about.
More On This Topic
Hello, my name is Yessenia Balan, and on behalf of Expert Village I'm going to talk about the proper techniques for singing. We're going to take the exercise down. So go ahead and start where I'm at, going down. Gentlemen, again, you'll be down here. "Ha... Read More »
Hello, my name is Yessenia Balan and on behalf of Expert Village I'm going to talk about the proper techniques for singing. Our next exercise will work out your abdominal. So we're going to go ahead if you can, put your hands in your abdominal area, find... Read More »
I'm Melina and welcome to Expert Village. Today, I am going to show you how to make screen print design on a t-shirt. The first things that you are going to need a regular piece of paper, where you?re going to draw a design. You?re going to need waxy... Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
You should select furniture making plans primarily on your skill level. Plans that are too complex or which require special equipment may only serve to frustrate you. Fortunately, furniture making plans and furniture "how-to" articles are widely... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
