Slowly Raising Hearth - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-06-2014, 11:03 AM   #1
Question
Slowly raising hearth
I have a slab of slate in front of my fireplace. Over the last six years, it has risen about a quarter of an inch above the floor. There aren't any signs of the house sagging or cracking around the mantle nor is there any signs of cracking in the mortar in the fireplace. In fact the bottom of the fireplace is still even with the slab. I can't imaging my whole house sinking, but it can't figure out what is going on. Any guesses?
sadrok is offline   Reply With Quote
Old 04-06-2014, 06:28 PM   #2
Rewards Points: 14,026
Is there a moisture barrier under the house.
Is there a particle board subfloor?
Old 04-06-2014, 07:22 PM   #3
It is a colonial with a basement so no moisture barrier and the flooring is standard plywood, no particle board. I'm thinking it might be moisture seeping in somewhere and causing the subfloor to swell, but it's strange that there isn't any cracking around the mortar where it meets the fireplace bottom, nor is the moulding shifted either. I can add pictures if it would help.
Raising a Fireplace Hearth fburdine Concrete, Stone & Masonry 6 12-12-2013 09:37 AM
Removing Fireplace Hearth - Questions dschribs Concrete, Stone & Masonry 14 02-25-2013 06:24 PM
Fireplace Hearth is Sinking Jim Ignatowski Building & Construction 9 01-04-2013 11:24 AM
Enlarging an existing fireplace hearth josephmartins Concrete, Stone & Masonry 0 11-09-2012 09:12 AM
Weight Support beneath brick hearth shub Building & Construction 2 01-10-2012 08:30 PM
