Old 09-23-2012, 07:18 PM   #1
slot cut in 2x4's
hey everyone, im having a home built and right now its at the stage of insulation and then drywall. I was walking around in it today and upstairs in every room i noticed that some of the 2x4's have had this slot cut into them and its pretty deep. Its marked with pencil so it doesnt look like its an accident, and then a nail is put in usually. Just wondering what this is for and why the builders do it? here are some pics
thanks gents
slot cut in 2x4's-2-x-4-cut.jpg   slot cut in 2x4's-cut-2-x-4.jpg   slot cut in 2x4's-cut2-4.jpg
bigpole is offline   Reply With Quote
Old 09-23-2012, 07:29 PM   #2
the Musigician
DangerMouse's Avatar
slot cut in 2x4's
I thought at first to pass wiring, but I've not seen that "style" before.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 09-23-2012, 07:34 PM   #3
Moderator
kwikfishron's Avatar
slot cut in 2x4's
Looks like a chain saw did that to me.
Although I've never seen that, it looks like it could be something that should have been caught and rejected at the mill and wasn't and your builder used those studs anyway.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 09-23-2012, 07:35 PM   #4
slot cut in 2x4's
I wonder if those studs weren't severely bowed and they made the cut to straighten them up?
I am curious to see what the experts say.
jonblack
jonblack is offline   Reply With Quote
The Following 2 Users Say Thank You to jonblack For This Useful Post:
oh'mike (09-23-2012), woodworkbykirk (09-23-2012)
Old 09-23-2012, 07:40 PM   #5
slot cut in 2x4's
ive been going to check the place out since it went up, and this is the first time i have noticed this. There are no wires on most of the pieces that have been cut,
could it be because they may have been bowed? but they werent cut all the way thru so how would that straighten them out? and then all of them have that nail.
its too straight of a cut to be done with a chainsaw, im thinking miter hand saw?
Old 09-23-2012, 07:47 PM   #6
slot cut in 2x4's
Check out this link:
what to do with a stud that crowns...
jonblack
The Following 5 Users Say Thank You to jonblack For This Useful Post:
bigpole (09-23-2012), DangerMouse (09-23-2012), mae-ling (09-23-2012), oh'mike (09-23-2012), woodworkbykirk (09-23-2012)
Old 09-23-2012, 07:51 PM   #7
slot cut in 2x4's
I think Jon nailed it. Usually I put a scab on the side, PLywood gusset works great.
mae-ling is offline   Reply With Quote
Old 09-23-2012, 07:56 PM   #8
slot cut in 2x4's
jonblock, maybe u are right with this! i will have to go and have another look. They are all marked with an x, so someone walked around and marked these specific ones off for some reason. it wasnt accidental thats for sure.
The Following User Says Thank You to bigpole For This Useful Post:
Old 09-23-2012, 08:00 PM   #9
Moderator
slot cut in 2x4's
A chainsaw made those cuts. Who marked the X's on the boards?
-NEW MEMBERS-
Old 09-23-2012, 08:02 PM   #10
slot cut in 2x4's
Hey, thanks everybody! My first "thank you" feedbacks.
I tried to do a little Google image searching, and the link above is what I came up with.
I like Mae-ling's idea about a plywood gusset. Maybe you can ask the framer if he would mind putting them on for you, just to make sure there are no problems in the future.
Thanks again
jonblack
Old 09-23-2012, 08:04 PM   #11
journeyman carpenter
woodworkbykirk's Avatar
slot cut in 2x4's
im with jon on this. its not uncommon to see a notch 1/4" deep by 1/4" wide on the edge of a stud coming right off the lift of lumber when back framing
if you see chunks of wood at inside corners, its pretty common to use scraps to create backin for drywall instead of wasting full studs
woodworkbykirk is offline   Reply With Quote
Old 09-23-2012, 08:22 PM   #12
slot cut in 2x4's
these cuts are like 3.5" deep so there isnt much wood left holding the 2x4 in tact, thats what im concerned about. I will ask some of the contractors when i see them hopefully before the drywall goes up.
i had a wuick look at these pieces and they didnt look bowed, maybe because this slot straightened them out?
i know there was a really bad bowed piece of wood, im going to go back tomorrow and check if that one also has this slot in it.
Old 09-23-2012, 08:31 PM   #13
slot cut in 2x4's
From what I can see, if looks like your photos show interior walls. I don't think you will have much to worry about in terms of bearing a load. However, if it were my walls, I would at least want a piece of 2x4 scabbed on where possible, at minimum.
Can you tell us about the "pocket" in the bathroom photo? Is that for a window or recessed medicine cabinet perhaps?
jonblack
Old 09-23-2012, 08:40 PM   #14
slot cut in 2x4's
yeah my builder did that too....they are too cheap and/or lazy to replace a bowed 2x4. That's a kerf cut...my builder was especially bad and thankfully out of business...
D270 is offline   Reply With Quote
Old 09-23-2012, 09:00 PM   #15
slot cut in 2x4's
I have had studs bow in a week! some were load bearing and not drilled for wires so we take em out and replace.
stacking 2x4s or sistering joists? dbeers02 Building & Construction 7 03-12-2012 12:46 PM
Sistering 2x4s for 2nd Ceiling cdogg36 Building & Construction 1 06-13-2011 01:30 PM
Replacing old 2 slot outlets with 2 slot + ground ibjames Electrical 9 09-28-2010 11:14 PM
Slot #3 blocked in Q0N Breaker Panel dallen Electrical 5 11-05-2007 07:37 PM
Useless Ridge Vent? itwerx2 Roofing 22 10-22-2007 10:57 PM
