-   -   Sloping Floor and back half of the house. Help! (http://www.diychatroom.com/f19/sloping-floor-back-half-house-help-302/)
mikeinfrisco 01-20-2005 06:40 PM
I recently purchased a two level, two unit San Francisco Victorian that noticibly slopes to the back and side. The back portion that slpoes includes the kitchen and the bathroom and I believe it was added on sometime after the original structure was built. (1900)
The foundation needs replacing and I'm not sure if the house would fare well if it was jacked up in those areas.
Needless to say I'm a bit nervous about the situation because the sloping drives me crazy living in those conditions. I was wondering if it would be best to build up the floors inside the house or from the foundation. What is the cost and infvolvement of each option?
Are there other resources that anyone might recommend? :confused:
Glasshousebltr 01-22-2005 09:50 AM
I'll bet your frame is a balloon type frame, they tend jack easy but you have to know what your doing. load placement is critical as well as gradual properly distributed lift. But I'll bet it will lift, anything will lift with right fella at the helm.
Research and find a really good contractor, this isn't a do it yourself project.
Bob
