Sloped Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-30-2010, 08:14 PM   #1
sloped roof
We are redoing one side of our roof it is a old house and the wood all needs replacing .It was built with 2x4's with 24in. centers . we intend to lift the roof and replace the entire roof .If we replace them with 2x6 is that up to code.
poetker is offline   Reply With Quote
Old 09-30-2010, 09:45 PM   #2
Chicago, IL
Michael Thomas's Avatar
Depends on the roof design, design load, rafter span, etc. See for example:
www.awc.org/pdf/STJR_2005.pdf
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-30-2010, 10:33 PM   #3
Registered User
Rewards Points: 5,216
Michael, that link put me back at the forum........ Try it yourself, maybe it's just me?
Here is a similar one: http://www.awc.org/calculators/span/...orizontal+Span
Gary
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 01:12 AM
sloped roof insulation imtryingtofixit Roofing/Siding 10 04-01-2010 08:52 PM
How to design and build attic closet over sloped roof Mendosherman Building & Construction 5 07-09-2009 03:15 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
