Sloped Joist In Simpson Non-sloped Hanger - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-30-2013, 01:09 AM   #1
Rewards Points: 95
Sloped joist in Simpson non-sloped hanger
I couldn't find the answer on the Simpson web site so I thought I would try here. Simpson states for a hanger like the lu26, "Joists sloped up to 1/4:12 achieve load tables", but they don't give any load reduction factors for other slopes, like 1/2:12 for example. Does anyone have any info on this, or is it just not allowed to go more than 1/4:12?
garya505 is offline   Reply With Quote
Old 07-30-2013, 10:54 AM   #2
Rewards Points: 12,808
Why not just cut out a notch in the bottom of the joist so the hanger is making full contact?
Hard to say without knowing exactly what it is your trying to build.
Old 07-30-2013, 03:22 PM   #3
Rewards Points: 95
It's just a patio cover, like a pergola but with a solid top. I'll have a ledger beam bolted to the wall, probably a 4x6 or 4x8. I can rest the rafters on the ledger if I use 4x4 or 4x6 for rafters, or use 2x6 rafters with a hanger like the LU26 or LUC26Z on the face of the ledger beam. The roof slope needs to be 1/2:12 or more to meet city code.
Simpson states that the LU26 can be used at up to 1/4:12 at the stated loads, but says nothing about a load reduction factor for a slope like 1/2:12.
Simpson Joist Hanger Question OKDrew63 Building & Construction 3 08-11-2012 05:05 PM
Deck joist hanger question - rim joist chrisv2 Building & Construction 2 08-09-2012 10:40 AM
Joist doesn't match dimension of joist hanger! Stan Shmenge Building & Construction 9 03-15-2011 08:35 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
