Slight Lean To Car Port - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-10-2007, 04:38 PM   #1
Rewards Points: 150
Slight lean to car port
Hi All,
I just noticed that my car port has a slight lean... about 1 to 2 degrees off plumb. The attached is a quick wire frame view of what it looks like and it's leaning to the left...
Any suggestions on how best to correct it?
slakker is offline   Reply With Quote
Old 10-10-2007, 05:01 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
You will need to add lateral bracing to the columns in both directions or brace it off a stable stucture.
You probably have post that are just boltes to the slab - this does not provide any lateral strength to the roof.
concretemasonry is offline   Reply With Quote
Old 10-10-2007, 06:13 PM   #3
Rewards Points: 150
I gues the tricky part is how do I bring it back to plumb? Or do I just brace it as is so it's doesn't shift any more?
Old 10-10-2007, 10:27 PM   #4
Custom Cabinet Maker
come-along and cable around top plate, attach to something real solid, plumb it slowly, then brace it up. Nearby tree, neighbors house
skymaster is offline   Reply With Quote
Slight slope to floor sweetsue777 General DIY Discussions 3 01-10-2007 01:58 PM
reflooring mobile home texas fishing port shu246 Flooring 1 06-25-2006 04:01 PM
squeeze & learn..slight problem Lin Electrical 1 02-06-2004 07:46 PM
