Sliding Mirror Door Track Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 06:12 PM   #1
I would like to install a sliding mirror door in a master bath. Do I install the floor track before installing the concrete backer board for the ceramic tile base.
CMaidment is offline   Reply With Quote
Old 01-07-2012, 06:18 PM   #2
Rewards Points: 14,312
Why not skip tiling inside the closet?
The bottom guide needs to be sitting on top of the tiles if you go that route.
You are talking about bypass doors right? Not a pocket door.
Better check the height of the door to make sure it will even work with the increased floor height.
Old 01-07-2012, 06:38 PM   #3
The closet door opening is 48x81, for a 48x80 bypass mirror sliding door. (There was a set of bifold doors there before.) I really don't want to drill into the tile. Could I install the track onto the 1/4" backerboard?
Sliding Door Installation Over Concrete Slab cobrakai Windows and Doors 2 12-11-2011 07:29 AM
Sliding screen door installation problem??? gabel8 Building & Construction 5 05-16-2011 07:22 AM
Condensation on baseboard by sliding doors... Donmills Flooring 0 06-28-2010 08:35 PM
Alside Sliding Door Installation sandyman720 Building & Construction 5 08-27-2007 12:50 PM
Sliding Patio Door Installation flyultralite Building & Construction 11 05-04-2007 11:06 AM
