Sliding Glass Door Shattered - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 01:40 PM   #1
Hi Everyone,
First post. I was hoping someone can help me out. I have a dual pane sliding glass door off of the balcony of my living room. Last week, I heard a loud "Crack" and saw the glass of the sliding door was shattered. I checked it out, and noticed it was only the inside layer of glass that broke. The layer of glass that is facing outside was still in perfect condition. I was not near it and I can not figure out what happened. I live in Southern California, so I know it was not a weather change. The door has been installed for about a year and it is used semi-often, so I do not think it was the installation. Also, I live alone, so I know it was not due to horsing around or anything. Any help/suggestions would greatly be appreciated!
Thanks!
aliplayer is offline   Reply With Quote
Old 02-27-2013, 01:49 PM   #2
Rewards Points: 528
I have had similar happen. Turned out that it most likely had a small crack from when the glass was cut.
Call the door manufacturer and ask them to come out and determine what happened.
framer52 is offline   Reply With Quote
Old 03-23-2013, 11:24 PM   #3
Tempered glass is a funny thing,
Sometimes nothing causes it break. When it
First breaks you can see a pattern and tell where the stress that broke it came from. If there are lock pins installed, you probably have your culprit. Ask the glass company to see if they see a reason. Sometimes bad framing, but them again maybe nothing.
sgjordan is offline   Reply With Quote
Old 03-24-2013, 12:10 AM   #4
Rewards Points: 258
tinny change in pressure and temp can do it. had a single pane window do that to me be once before.
redman88 is offline   Reply With Quote
Old 03-24-2013, 12:45 AM   #5
A typical glass warranty will cover spontaneous breakage within the first year. The reason being that if tempered glass left the manufacturer with a flaw, it would break within the first year of the life of the installation in the residence with settling and such.
Aserviceperson is offline   Reply With Quote
Old 03-24-2013, 06:28 AM   #6
Roofmaster
Rewards Points: 2,172
As long as the door is sliding easily this is probably a warranty issue. Call the guy that installed it, he should help you out here.
Old 03-24-2013, 06:34 AM   #7
Rewards Points: 164
If it has a tint to it , the guy that installed it put it in backwards, when having a tint to a slider there is a way and only one way it needs to go, if not the sun would heat up one side and break it..
bostonwindows30 is offline   Reply With Quote
Old 03-24-2013, 08:56 AM   #8
Lord of Slums
Rewards Points: 1,974
Microscopic imperfections in the glass. Tempered glass is a funny thing. This is a more common problem than you would think.
mj12 is offline   Reply With Quote
Old 03-24-2013, 07:13 PM   #9
What brand of door do you have?
Old 03-25-2013, 09:47 AM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,786
Not a temperature or pressure issue.
Very likely a fault in the glass as mentioned.
Help with sliding glass doors. ob2s Windows and Doors 8 05-30-2012 09:54 AM
sliding woodframe glass doors stephenbishop Windows and Doors 1 03-13-2012 08:11 AM
Pella sliding glass door trim seperated from glass Scuba_Dave Building & Construction 6 03-10-2011 01:28 PM
Moulding Around Sliding Glass Door JRMN Building & Construction 8 08-03-2010 12:22 PM
Replacing Sliding Glass Door w/ French Doors zapatero3 Remodeling 1 07-15-2010 06:01 AM
