Old 08-26-2011, 10:07 PM   #1
sliding glass door
I just had a new sliding glass door installed and seems to be installed correct. I did a hose test to see if it leaks, and it does!. Now any good, brands of doors?
Pam S. is offline   Reply With Quote
Old 08-26-2011, 11:32 PM   #2
Super Moderator
sliding glass door
Anderson----top of the list.
Fix the leak---
oh'mike is online now   Reply With Quote
Old 08-27-2011, 11:37 AM   #3
sliding glass door
I don't understand this post. Why are you asking about doors if you just put one in?
You could put in an Andersen door incorrectly and it will leak.
Call back the Yahoo's that installed it and have them fix it.
Before they arrive, I'd do some research and find out what the proper way is, so you can make sure it gets done correctly next time.
What door do you have?
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
tpolk (08-27-2011)
Replacing a sliding glass door question cdm Carpentry 45 04-11-2011 05:12 PM
Installing 16ft sliding glass impact door dario08 Building & Construction 1 09-29-2010 07:00 PM
Exterior Trim-Sliding Glass Door Elshupacabra Remodeling 2 06-19-2009 02:17 PM
Sliding Glass Door Replace: Help roztom Building & Construction 4 07-22-2008 09:07 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
