Sliding Door Glass Replacment - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2007, 01:11 PM   #1
I have a Pella sliding glass door where the outside pane of glass has spider webbed and is now taken out. What is the correct procedure to remove the existing glass frame and inside piece of glass to take it to a repair shop?
There is wood trim that I've removed from around the frame...but the glass and frame does not easily come out.
Tks in advance.
Broken and in pane...
ryans is offline   Reply With Quote
Old 04-18-2007, 07:01 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Tks in advance.
Hi Ryan,
Tho, I install Pellas, I am not real familiar with the 'exact construction' of Pella sliders. I would suggest that you first contact Pella to confirm that you can even do what you want to do. Give them the 'model' of the slider. In all probability the panel may be a sealed unit, and the glass not replacable. An entire new panel might need to be ordered.
(If Pella says that your slider model's glass can be replaced - Contact a 'glass company' and ask them if they are willing to take the whole panel and remove the damaged glass for you - prior to them installing the new glass - in the panel....)
Good Luck
- Build Well -
Old 04-18-2007, 09:49 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
If you are in a major metro, markey you may be able to have it replaced quickly at a reasonable cost, all things considered.
I bought a 26 year old townhouse that had a fogged IGU panel. It was the older 6' wide that is wider than todays 6' units.
I called for prices at several glass stores, but you usually need an exact measurement (height, width AND thickness).
The sercice man came out with his truck to measure the panel. It turned out to be a fairly common size and he had a replacement unit.
Twenty minutes later, I had a new unit installed, the door wheels cleaned and adjusted, the screen wheels cleaned and adjusted for about $230.
All things considered, it was a good deal. I could have taken the unit out, taken it in, had a new unit made, installed, cleaned... etc., but it didn't make sense to go through all that and the time and running around.
Call around. You may find something good. If you have an odd size, you may wait a day or two, but supposedly the price is not that much different since all units are made in the local shop.
concretemasonry is online now   Reply With Quote
sliding glass door security... sflamedic General DIY Discussions 5 07-31-2009 02:00 PM
12" Sliding Compound Mitre Saw jr66 Tools 7 05-28-2007 05:12 PM
Sliding Patio Door Installation flyultralite Building & Construction 11 05-04-2007 12:06 PM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 01:43 AM
Sliding Glass Doors Drewimus General DIY Discussions 2 10-02-2006 10:06 PM
