Sliding Anchor System? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-02-2011, 03:59 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 816
Sliding anchor system?
I'm building a 2-story addition to my house....
Several of the walls are braced/shear walls.....a couple of them being C & D's.
Per the drawings, the sole plate has to be 3x and use "SLIDING ANCHOR SYSTEM" with 1/2" lag bolts at 24" and 18" OC respectively screwed into 4x below.
This sole plate is sitting on top of a sub floor with 2x8 rim joist and 2x8 blocking between the floor joists. I built it this way because that is what the detail showed.....but now I'm thinking that rim joist should have been a 4x8.....
Is this correct? And....what are my options? Almost afraid to mention it to the architect because he is the one that will have to do a "Observation Report". The building inspector already bought off the sub-floor and most likely will not climb under the house to see if I have the 4x's in there.
sliding door and water leakage basketlady8 Windows and Doors 3 08-15-2011 05:12 PM
Sliding Glass/French/Patio/Sliding French??????? Evil Scotsman General DIY Discussions 3 03-15-2011 12:35 PM
Moulding Around Sliding Glass Door JRMN Building & Construction 8 08-03-2010 12:22 PM
Condensation on baseboard by sliding doors... Donmills Flooring 0 06-28-2010 09:35 PM
Possible to add sliding screen/storm door to exterior door? Grifftech General DIY Discussions 1 06-01-2010 09:56 PM
