Slate Tile & Sealing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-20-2009, 01:46 AM   #1
I am sealing my slate tile with DuPont Semi-Gloss water based sealer BEFORE I am going to install it. I accidentally sealed the wrong side of a tile.
Do I have to remove the sealer or will the thinset still adhere to the tile even with a sealer installed?
JackOfAllTrades is offline   Reply With Quote
Old 09-20-2009, 05:59 AM   #2
Remodeling Contractor
if you can pressure wash the sealer off the bottom first.
Old 09-20-2009, 07:15 AM   #3
ccarlisle's Avatar
One tile?
That's Dupont's acrylic topical sealer you put on there and most probably sensitive to high caustic floor wax strippers. Use that if you have it, or spray on EasyOff oven cleaner...then rinse real well.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 09-20-2009, 03:36 PM   #4
Registered User
Termite's Avatar
You're not putting slate in a shower are you? Trust me, I didn't heed the warnings I was given and I've regretted it every day since. It was beautiful for a few months and now it is a mess despite my best cleaning efforts. I used $84/quart (15 year) sealer, applied two coats, and it looks like crud a year later.
Old 09-20-2009, 06:14 PM   #5
NOPE. I am putting the slate on a fireplace wall.
From what I heard, slate is NOT good in high traffic areas and areas that get a lot of water (showers).
I was told to SEAL the slate first BEFORE installing, as getting the grout and thinset cleaned off of the many groves and pits in slate is a nightmare.
Old 09-20-2009, 06:15 PM   #6
Originally Posted by ccarlisle View Post
One tile?
Yes, 1 tile.
I might just use brake cleaner on the tile to remove the sealer. That stuff removes anything and drys immediately, leaving no residue or any oils.
Slate tile Termite Flooring 14 04-01-2010 09:05 PM
Slate Tile Roof Cleaning Tampa Florida - Slate Roof Cleaning Using Lift. apple roof cleaning Roofing/Siding 1 12-31-2008 10:01 AM
marble tile over existing slate and concrete flooring bullrage22 Flooring 13 05-19-2008 07:58 PM
Slate Tile... Jshakour Flooring 13 04-24-2008 10:34 PM
Natural Slate tile Akeith Flooring 5 03-21-2006 05:13 AM
