Slate Tile On Concrete Basement Floor... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2008, 08:10 AM   #1
Rewards Points: 324
Slate tile on concrete basement floor...
Just looking for all around pros and cons.
I dont mind the cold feel of the current concrete floor so thats not a concern. There will be a pool table down there but I guess I could get a rug if I start to break balls or crack tiles.
tigerbalm2424 is offline   Reply With Quote
Old 06-13-2008, 04:47 AM   #2
i'd probably acid-stain the floor
yes.itsconcrete is offline   Reply With Quote
Old 06-13-2008, 06:04 AM   #3
Rewards Points: 156
I did it
I have dark slate on my basement floor. It's colder than an icebox in the winter but then again, so is concrete. I sealed it up pretty well and after a year, no cracks. It's stronger than it looks. I know a lot of people use it outside too so I wouldn't worry about it holding up.
jayp is offline   Reply With Quote
Old 06-13-2008, 07:02 AM   #4
i'd never use tile/flagstone outside where there's ANY chance of freeze/thaw,,, its only a matter of time til it delaminates,,, even here in marietta, ga,,, but it does look pretty,,, yours looks like indian slate - not a great mtl for strength but cheaper than u s slate from vt/va/pa & certainly striking in appearance.
Old 06-13-2008, 08:44 AM   #5
If the slab in a basement freeze and thaws you must live in antartica.
dundeeslugger is offline   Reply With Quote
Old 06-13-2008, 09:45 AM   #6
Rewards Points: 156
yes
Yeah, there's no way your basement slab is gonna get cold enough to screw up your slate.
Old 06-13-2008, 10:33 AM   #7
ooops - was a basement question,,, forgot !!!!!!!!!!!!!!
Old 06-13-2008, 10:49 AM   #8
Rewards Points: 324
Anyone know the weight of 1/2" 12"X12" slate tiles? I needs to transport 500 sq ft to my house and need to know the weight!
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Carpet and slate tile on same basement floor CBH Flooring 14 06-12-2008 03:14 PM
marble tile over existing slate and concrete flooring bullrage22 Flooring 13 05-19-2008 07:58 PM
Tile and slate floor ??? Clutchcargo Flooring 16 01-01-2008 07:03 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
