Old 08-04-2012, 10:22 AM   #1
slanting walls in elevation
what sustainable material can be used for constructing slanting walls ?
Neslin Rose is offline   Reply With Quote
Old 08-04-2012, 10:32 AM   #2
Experienced
Jackofall1's Avatar
Hello and welcome, to the best DIY site on the web, but you will have to be a lot more decisive to generate an answer.
Old 08-04-2012, 12:16 PM   #3
Walls slanting in plan? low or high walls? battered walls? retaining walls? internal partition walls? parapet walls? free-standing boundary walls?
tony.g is offline   Reply With Quote
Old 08-05-2012, 11:59 AM   #4
Framing Contractor
No explanation, no answers. What are the walls for?
Joe Carola
Joe Carola is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
No Floating walls where there should be! DIY Master Building & Construction 1 02-23-2011 06:06 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
