Slab Thickness - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 02:57 PM   #1
Rewards Points: 640
slab thickness
I am trying to cut a hole in the houses slab for some drain pipe to be put in, right now I am no where near the footer and the slab is 9 inches thick it appears... is this normal? everything I read says a houses slab is usually 4" thick and the footers are thicker.. it appears they poured the footers, laid the block then brought the slab up to the almost top of the first course of block, because I can just see the top of it on the permitier of the slab...
making cutting a pain in the ......
BlueBSH is offline   Reply With Quote
Old 01-05-2012, 03:10 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
How do you know you aren't cutting over the top of an interior concrete beam?
XXX
Old 01-05-2012, 03:41 PM   #3
DIY staff
Rewards Points: 7,174
Might be just a thick spot---or you could be at the house I helped build where the contractor poured a 14" thick slab just to keep a job on schedule---
oh'mike is online now   Reply With Quote
Old 01-05-2012, 03:48 PM   #4
Rewards Points: 640
going by the plans for the house construction, there should be nothing under this section
Old 01-05-2012, 03:50 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"Proposal Plans" or "As-Built Plans"?
XXX
Old 01-05-2012, 03:52 PM   #6
Rewards Points: 640
these are the plans the builders used, so I'd assume built plans, I also have a copy of the set turned into the building department they are marked as "proposed" the others are slightly different but still nothing in the area i'm at
Old 01-05-2012, 03:59 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Don't know but plans are not always totally reliable when it comes to where underground improvements are installed.
Assuming you are ultimately doing a trench...
Move down line and cut there and see what you find.
XXX
Old 01-05-2012, 04:17 PM   #8
Civil Engineer
Rewards Points: 4,518
Did your plans state the thickness of the slab? A 9 inch thick slab is unusual for residential, in my experience 4 inches is pretty common. You do not state where you are, there are parts of the country where thick, prestressed slabs are commonly built, you had best make sure you do not have one of those, cutting through a prestressing tendon would make for a very bad day for you.
Daniel Holzman is online now   Reply With Quote
Old 01-05-2012, 04:25 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good point!
It could also be a "post-tension" slab.
Any signs of that around the exterior of the slab?
Where are you and how old is this slab?
XXX
Old 01-05-2012, 04:30 PM   #10
Rewards Points: 640
Good point!
I'm in western pennsylvania, the house was built in 1997
Cutting through this is extreamly hard, never saw concrete this hard to cut through..
got about 3 ft down the line now and its pretty much a consistant 8-9 ish inches...
where there is a shrink gap near the wall I can push a metal wire about 9 inches down until it hits the footers, and you can feel it hit... haven't hit any rebar or wire mesh, but it did have the plasic vapor barrier under it before the gravel
Old 01-05-2012, 04:31 PM   #11
Rewards Points: 1,092
Is it not possible to get a "sonar" device to find out the profile of your slab? I saw a concrete company "ping" a slab to determine that it was sound (no pun intended) and assumed it was some kind of sonar deal... or maybe just showmanship to make the owner think somebody did something.
Old 01-05-2012, 04:52 PM   #12
journeyman carpenter
woodworkbykirk's Avatar
4" is the minimum thickness for a slab, they typically can vary within the 4"-5" range if the backfill was properly graded.. in your situation its possible the guys who did the foundation work didnt allow for the correct amount of 3/4 stone to backfill with so there is a large section which is thicker than the rest. could be do to a severaly out of level footing too so they had to create a level slab.. the footing being out of level isnt a big deal it just made things harder for the guys doing hte actual foundation wall, the slab finishers and the framers... as long as everything is structurally sound,, you only stress will be cutting out the extra thick concrete
woodworkbykirk is offline   Reply With Quote
Old 01-05-2012, 05:44 PM   #13
Is this in the basement of a home where they may have poured monalific footing/slab for lally columns?
glkirk is offline   Reply With Quote
Old 01-05-2012, 07:01 PM   #14
Rewards Points: 640
monolithic footings? you mean like the entire slab is a footing? if thats what you mean, it does have independent footings going by the design specs, and the block on the outside walls go at least 1 course below the slab grade, you can see the top maybe 1/2" of the first course from inside the basement. its shown being built like this in the building plans
http://www.infoforbuilding.com/basementfoundation.gif
Old 01-05-2012, 07:34 PM   #15
Are you cutting close to a lally column?
raised slab foundation tclark Building & Construction 6 01-07-2011 09:10 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
slab thickness jad Building & Construction 6 09-11-2010 09:39 AM
recommended slab thickness? walkman Building & Construction 6 11-16-2009 07:19 AM
what slab size relative to thickness ? ? ? yesitsconcrete Building & Construction 20 04-09-2009 07:08 PM
