Slab On Grade? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 06:35 PM   #1
gnu
slab on grade?
Hi, I am attempting to gather infromation for a woman on a fixed income hoping to build a small home, maybe 700-900 square feet, depending on the local zoning. It will be located outside the Guelph area in Ontario.
I am new to new construction but was wondeirng, in order to cut costs, is slab on grade feasible? Are the saving at the front end going to cause more expense later if the ground heaves or is that not a concern? I am not positive of the soil condtion. Is there anything else I should be concerned with?
As this is my first post and I am in the prliminariesof gathering all info I can for her I was wondering if ayone is aware of any other sights that might be of use.
gnu is offline   Reply With Quote
Old 02-12-2011, 06:38 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So what do your soil sample reports say?
XXX
Old 02-12-2011, 10:54 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Hi gnu and welcome to the forum.
Sounds like an honorable thing you are doing for her. Wow though, where to start?
There are innumerable things to know about starting a ground-up construction. You need to start with finding a professional in your area I think to help you find a proper plan for this. A designer or Architect that will be sympathetic to her plight perhaps?
Your local Building Department might be a good place to start in locating someone.
To answer your question though I believe there are techniques for pouring slab-on-grade without digging to the frost line.
Sorry, not much help I know.
Andy.
AndyGump is offline   Reply With Quote
Old 02-12-2011, 11:45 PM   #4
gnu
Thanks for your answers, I wont' have a soil reprot until the spring thaw, do hou know what my options are if it is sandy vs clay as far as a foundation.
Andy, you mentioned there are inumerable things working from the ground up. what are the top three things, in your opinion, I should be starting with???!!!!
Old 02-12-2011, 11:53 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You need a plan.
Your architect/engineer will be able to advise you of any excavation and soil modifications that may be required.
XXX
Old 02-13-2011, 12:52 AM   #6
AndyGump's Avatar
Rewards Points: 660
In my experience if you have expansive soils then the foundation and especially the footing needs to be either thickened, deeper more re-bar or all three. Ask the city if they have a prescriptive solution for the foundation detail. Likely they will but that solution might or might not be more expensive than what can be engineered to work.
Andy.
Old 02-13-2011, 06:32 AM   #7
gnu
That was helpful. She isn't gong to purchase the land until we can 'nail down' a few more of the costs. There is no room for financial errors here. I will check with the township on Monday.
Old 02-13-2011, 10:28 AM   #8
Civil Engineer
Rewards Points: 4,520
The Guelph area is not known for expansive soils, however it is well known for cold winters and deep frost line. The local building department will tell you the design frost depth, and will almost certainly be able to discuss foundation options that are used in the area.
Slab on grade above the frost line requires special techniques to minimize the potential for frost heave and other problems. You should discuss these issues with the building inspector before purchasing the land, as the cost of the foundation for a small house can amount to a significant fraction of the total cost of the house.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
AndyGump (02-13-2011)
Old 02-13-2011, 12:56 PM   #9
gnu
Yes it is the frost line and cold winters I am concerned with as well. I am thinking at least a crawl space will need to be poured and hopefully cut down on the cosst.
I have never built new and am over my head for sure.
Thanks for your input
Slab on grade home gwbossio Building & Construction 2 09-07-2010 10:19 PM
Adding a footing to an existing slab on grade jascox Building & Construction 4 07-05-2010 03:20 PM
engineer wood floor @ uneven Slab on grade gtimk4 Flooring 0 03-21-2010 07:29 PM
Floor Drain retrofit for Slab on Grade Douger_F Plumbing 3 04-02-2009 12:07 PM
conduit in slab grade ugabulldog Building & Construction 4 06-10-2008 09:23 AM
