Skylight Install - Cutting Attic Joist Crossbeams? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2010, 02:09 PM   #1
Skylight Install - Cutting attic joist crossbeams?
I'm going to be installing a skylight in the middle of this picture, cutting through the middle joist. That means that I'll have to cut through 2 "crossbeams" (I don't think they are called rat runs because I don't have a truss), here is a pic:
http://img178.imageshack.us/i/img5813s.jpg/
This is a pic of one of the crossbeams (they are 15' long crossbeams, spanning 11 joists which are 16"OC):
http://img685.imageshack.us/i/img5814t.jpg/
They are on the other side of my attic as well, 3 of them, 15' each, spanning the entire length of my house, overlapping on a joist as you saw in the first pic.
My questions:
1. Am I allowed to cut them?
2. If yes, what do I need to do before & after I cut them (i.e. Put additional ones on? Full 15' ones, or just long enough to span a few joists? Move the entire 15' existing ones instead of cutting them?)?
Keep in mind I'll be splaying the skylight front/back so if I need to replace the crossbeams, they will not be in-line with the existing ones, they will be several feet closer to the middle of the attic and/or several feet closer to the edge of the roof to make room for the splayed skylight walls. And yes, I know I need to deal with all those wires that are in the way, fun fun fun.
spup345 is offline   Reply With Quote
Old 08-26-2010, 10:41 AM   #2
Got my answer elsewhere. Basically, they are rat runs, not structural in nature (helps folks walk in attic and solidify joists), can just put a couple of additional ones in front & back of the skylight walls spanning 7-8 joists, then I can cut the ones in the picture and double-up everything as needed for the skylight frame. Thanks.
attic joist support kimallen123 Building & Construction 3 05-04-2010 12:31 PM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
Attic gable fan install mattmcl HVAC 2 04-23-2008 09:26 PM
Cutting brick to install windows (lentals?) buckwillis Building & Construction 6 08-21-2006 08:13 PM
correct joist size for attic helpless handyman Building & Construction 1 07-05-2006 11:29 PM
