Old 08-04-2006, 11:24 AM   #1
Skylight Dilemma...
I have some skylights in a new cathedral ceiling. I have high-heel roof trusses so there is 19.5 inches from the roof sheathing to the drywall on the sloped ceiling. The trusses are on 24" centers. I have a well insulated and sealed box framed around each skylight (the trusses make up the sides). Two different drywall guys said they didn't recommend using drywall inside the boxes (from roof to cathedral) as the corners would surely crack. They recommended finishing like a window or door with wood all around. We like the "drywalled" look that you see in many skylight pictures. If it's not done with drywall, then how is it done? I can see the potential for cracking would be great perhaps if there was a tunnel from a flat ceiling...through an attic...to a sloped roof...but in this case, I would think there would be very little relative movement between the surrounding surfaces. Any thoughts on this would be appreciated! Thanks!!
sootybuttercup is offline   Reply With Quote
Old 08-04-2006, 04:58 PM   #2
Master Craftsman
Big Dave's Avatar
Skylight Dilemma...
We always drywalled them. Sounds to me like they didn't want to mess with hanging them, they are a PITA. We never had any problem with them cracking.
Dave.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 08-04-2006, 08:28 PM   #3
renovations
Skylight Dilemma...
I've certainly drywalled them without problems, even through a flat ceiling. They are a PITA, though.
Bonus is offline   Reply With Quote
Old 08-04-2006, 08:42 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Skylight Dilemma...
Sootybuttercup,
If they are concerned about the corners cracking, my question is:
What kind of framing do you have installed in the corners?
If there are no corners to attach the sheetrock to for the entire length of 21.5" (also figure in a chamber where temperatures can fluctuate and wood will expand and contract)...then, there is some cause for concern on their part.
Otherwise, there should be no problems drywalling the areas.
- Build Well -
Old 08-09-2006, 05:33 PM   #5
Skylight Dilemma...
Works for me...drywall it is. Thanks all!!
Skylight ceiling opening mt232 Remodeling 2 05-15-2012 05:00 PM
Roofing materials dilemma?????? Jms92 Roofing 29 02-19-2008 01:14 PM
New vented skylight in existing roof lightninrodman Remodeling 1 07-26-2007 07:47 AM
Replace a skylight dome only?? Phil Ervin General Discussion 12 05-28-2006 08:32 AM
Skylight leaking advice needed!Thanks Beeper29x Roofing 12 10-04-2005 09:53 PM
