Old 04-20-2005, 04:39 AM   #1
Unhappy
Skirting on Curved Walls
Hi Everyone, need some advice. I have had some snew flooring and skirting put in but where I have 3 bits of curved wall the builders have cut the skirting into bits and joined it together. I am sure this is not the right or clean way to do this and want to prove it to them.
Does anyone have the correct instructions with diagrams I could show these guys and get them to do the job properly?
Please help, the builders finish tomorrow and I want them to sort the skirting out before they leave!
Harjy is offline   Reply With Quote
Old 04-20-2005, 02:39 PM   #2
Send a message via AIM to urbansurgery
the only time i have seen this done is almot as you describe and in pieces
however
there are of course many wys to skin a cat
are they putting the pieces butt end to butt end - thats a very easy but cheap solution
the way if sen it down successfully is where pieces ahave been bent and spliced together on an overlapping angle and then plugged through and glued together. that is a chamer to the rear of one piece and a chamfer to the front at the other end - overlapping a bit like fish scales - so ft echamfer is quite long
it takes a good craftsman to do and usually costs - did you prespecify with the builder the way it should be done?
i dont have photos available - i have one i work know for sure but i cant get that in time for their departure
urbansurgery is offline   Reply With Quote
Old 09-10-2005, 11:08 AM   #3
I assume the workers are long gone. If you are looking to try and redo the molding the here is a link to an another trim question about curves. I too could not find any illustrations. http://discussdiy.com/showthread.php...stid=51#post51
Mgmopar
MgMopar is offline   Reply With Quote
