Skirting - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 09:05 PM   #1
skirting
how to instal vinyl lattice
djl123456 is offline   Reply With Quote
Old 07-10-2012, 09:08 PM   #2
Rewards Points: 14,306
With screws.
Come on now tell us what it is your trying to do. Yes we know installing lattic,
on what a fence, a wall, under a deck?
Old 07-10-2012, 09:09 PM   #3
Rewards Points: 6,652
Lots of duct tape, and Carpenter's nails.
Old 07-10-2012, 10:04 PM   #4
Rewards Points: 150
Originally Posted by joecaption View Post
With screws.
Isn't it obvious from the title. He is making scorts out of vinyl lattice.
Personally, I avoid vinyl lattice and stick with the real stuff because I don't like the look.
goosebarry is offline   Reply With Quote
Old 07-10-2012, 10:10 PM   #5
Rewards Points: 83
Because I don't do a lot of scorting, I usually just rent a scorter from HD or RONA. They usually aren't the best scorters, but if you only have to scort a few things, they work just fine.
rubberhead is offline   Reply With Quote
Old 07-10-2012, 11:13 PM   #6
AHH, SPANS!!!
Rewards Points: 1,166
Did you mean Skirting? is this a scort-a-thon
hand drive is offline   Reply With Quote
Old 07-11-2012, 12:24 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
"Scorting"? Ok, so maybe he means 'vinyl lettuce'
Old 07-11-2012, 02:54 PM   #8
Rewards Points: 150
With screws.
To the OP. it appears we haven't scared you off. Answering joecaption's questions would help as well as providing some dimensions.
Old 07-11-2012, 03:10 PM   #9
gooseberry, the OP was not real to begin with. These search engine type questions are actually robots.
The Following User Says Thank You to gregzoll For This Useful Post:
goosebarry (07-13-2012)
Help with attaching skirting to a pier and beam house will04 Building & Construction 15 09-08-2011 01:04 PM
laying laminate floor without using beads and skirting board is in and to the floor phil portman Carpentry 2 08-03-2011 08:36 PM
stair skirting boards nanna Carpentry 3 11-27-2010 09:05 PM
Painting Skirting Boards and paint dripped into the tile grout naomit111 Painting 2 11-10-2010 09:04 AM
Help a beginner out with concrete skirting 1nonly Building & Construction 5 01-22-2008 04:43 PM
