Sizing Pier Footers For House. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-08-2009, 08:09 PM   #1
Sizing pier footers for house.
Hello,
I am going to build a small cabin 26' X 40'. One story wood. cabin will have a center beam 3-2x12s(for floor). frost line is 12" and ground is rated 2000 psf. tallest pier will not be more than 8 feet. I would like to use sonotubes. Maybe someone can help me with the spacing and sizes. and how about redibase or something like it.... Thank you....
woolfmaster2011 is offline   Reply With Quote
Old 07-08-2009, 10:52 PM   #2
Rewards Points: 5,336
I think you might need some professional guidance on this. That "8 feet " off the ground was the tipping point for me.
Ron
Old 07-08-2009, 11:52 PM   #3
I think you are right(find a SE). The cabin is on a sloped land. only one side will be 7-1/2 ft tall the other lets say 24". most of the older homes(50yr) near me are on concrete block piers. Truth is i am limited on money to build. Maybe this is not the way to go? is there a low cost foundation?
Thanks.
Tags
footer , piers , size , sonotube
Pouring pier footers - are forms necessary? jcims Building & Construction 2 06-15-2009 11:53 AM
Need advice on footer pier problem paredown Building & Construction 3 03-20-2009 10:08 PM
footers?? smith Building & Construction 10 02-04-2009 07:25 AM
rebar in footers ajoantmug Building & Construction 11 11-18-2008 10:11 AM
Dek Building- pier to post connection- necessary? k man Building & Construction 4 09-28-2008 06:21 PM
