Old 09-16-2008, 03:24 PM   #1
Size/Type of Nails for Interior Framing?
Hello.
I will have a Paslode F-350S 30 degree type D stick nailer and a Paslode F325C coil nailer.
What nails do I need for interior framing basement 2x6 and 2x4 walls non-load bearing?
8d for toe nailing and 16d for face nailing?
Should I just get all stick nails or should I get coil nails for the face nailing and stick for the toe nailing or does it matter?
Whats better/most used in the Canadian workplace?
Matt
mfleming is offline   Reply With Quote
Old 09-16-2008, 06:50 PM   #2
For framing I'd use 16D for everything.
Ron
Old 09-16-2008, 09:39 PM   #3
Idiot Emeritus
I usually use 3-1/2" for nailing plates to studs, I like the idea of as much penetration into end grain as possible. These are good for toe-nailing as well.
I nail top plates together with 3-1/4", that way the end sticks out just a bit, so I know where not to drill holes.
I use 2-3/4" ring shanks for trimmers, invariably you'll shoot one right where you need to mount an electrical box, and these don't stick out at all.
Rob
micromind is offline   Reply With Quote
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
cut nails ugabulldog Flooring 2 04-23-2008 12:19 PM
Rusty nails FatAugie Roofing 6 08-28-2007 10:25 AM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 11:54 AM
Deck nails jimgibson Carpentry 12 10-09-2005 03:22 PM
