-   -   Size/Type of Nails for Interior Framing? (http://www.diychatroom.com/f19/size-type-nails-interior-framing-26911/)
mfleming 09-16-2008 02:24 PM
Hello.
I will have a Paslode F-350S 30 degree type D stick nailer and a Paslode F325C coil nailer.
What nails do I need for interior framing basement 2x6 and 2x4 walls non-load bearing?
8d for toe nailing and 16d for face nailing?
Should I just get all stick nails or should I get coil nails for the face nailing and stick for the toe nailing or does it matter?
Whats better/most used in the Canadian workplace?
Matt
Ron6519 09-16-2008 05:50 PM
For framing I'd use 16D for everything.
Ron
micromind 09-16-2008 08:39 PM
I usually use 3-1/2" for nailing plates to studs, I like the idea of as much penetration into end grain as possible. These are good for toe-nailing as well.
I nail top plates together with 3-1/4", that way the end sticks out just a bit, so I know where not to drill holes.
I use 2-3/4" ring shanks for trimmers, invariably you'll shoot one right where you need to mount an electrical box, and these don't stick out at all.
Rob
