Size Of Slab For Covered Patio, Relative To Size Of The Cover? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 08:03 PM   #1
Rewards Points: 95
Size of slab for covered patio, relative to size of the cover?
I'm putting up a covered patio and first will need to get the slab poured. I have a good idea of the size of the cover, so now I'm wondering how big to make the slab. Adjacent to the slab will be gravel on one side and pavers on the other two side. Here's the big question. Should the edges of the cover be over the patio slab, or overhang the gravel/pavers? The roof will be a shed type so water will drain off the one end (eave), but I guess there could be some small amount dripping from the two sides.
garya505 is offline   Reply With Quote
Old 07-14-2013, 08:44 PM   #2
Rewards Points: 1,016
The slab should be smaller than the overhead, especially at the front - so rain water does not drain directly on the slab.
____________
Vince
The Following User Says Thank You to vsheetz For This Useful Post:
garya505 (07-15-2013)
Old 07-14-2013, 08:45 PM   #3
Rewards Points: 12,790
Just need the slab out far enough to cover the footings that your going to need to hold up the roof.
You need over hangs on all sides!
You need footings where the post are going to be.
Going to need 6 X 6'S not 4 X 4's.
Need post bases under every post so they do not rot out at the bottom.
Old 07-15-2013, 04:44 PM   #4
Rewards Points: 95
Thanks for the excellent replies. After posting the question I was watching the rainwater drain off my shed and thinking the same thing about the patio overhangs.
Details-combining slab foundation and patio wwsteel Concrete, Stone & Masonry 11 03-22-2013 12:20 AM
Turning patio slab into screened/roofed patio usaf-denalidrw Building & Construction 7 03-10-2013 09:38 AM
Building a new patio cover without footers MStarr Building & Construction 8 01-31-2013 10:06 AM
New patio cover and/or enclosed patio jcrizzy Building & Construction 9 01-28-2013 12:30 AM
Patio cover Jackhammer Building & Construction 3 07-10-2007 04:49 PM
