Size Of Frieze Board For Horse Barn? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 06:01 PM   #1
Rewards Points: 37
Size of Frieze Board for Horse Barn?
36' x 60' Horse Barn....10' ceiling height in the barn (1st floor)....9/12 pitch roof with a loft on top of the first floor ---- about 23' to the peak....rake board on the gable end measures about 24'....9' 6" height on the eaves.
Going with 6" Versatex Corners....Should I go with 4" or 6" Frieze Boards along the rakes and eaves....which will look better aesthetically?
Thanks for the help!
hagler is offline   Reply With Quote
Old 03-20-2012, 06:23 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
depends,whats the siding exposure? are any windows or door heads close to the soffit elevation? whats the w/d trim detail?usually all things considered wider = better
Tom Struble is offline   Reply With Quote
Old 03-20-2012, 06:43 PM   #3
Rewards Points: 528
i like 12" freeze boards myself....
framer52 is offline   Reply With Quote
Old 03-20-2012, 07:10 PM   #4
Rewards Points: 37
T-111 siding...8" O.C.
on the 60' side (under the eaves):
- 4" window & door trim...
- 7' dutch door height under the eaves 3' clearance from soffit
- one window 6' long x 42" height .....3' clearance from soffit
36' side (gable end):
-12' x 10' main sliding doors on 1st floor
- 5' x 6' loft door.... 5' clearance from peak
- windows are low on 1st floor centered on 12' panels on each side of main barn doors ---- windows are 36" x 42" (non-factor)
Looking at band board above main barn doors (where the track will be mounted)....probably 10" or 12"
This is new construction, so just ordering and planning right now.
Opinions? Is 6" too wide.....4" too narrow?????
Thanks.
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 11:32 PM
Cut Ends of Barn Board DanFromOhio Carpentry 4 03-30-2009 09:52 PM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
Ridge board enough? runningforyou Roofing/Siding 9 08-13-2008 08:43 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
