"Sistering" Wood Together - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2008, 05:18 AM   #1
"Sistering" wood together
What is the proper way to sister a 2x10 to a 4x10 rafter? Length is 20' Do I use nails or bolts? What is the nailing or bolting pattern?
TVC15 is offline   Reply With Quote
Old 08-23-2008, 06:18 AM   #2
Whatamess
Did you mean sandwich the two?
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-23-2008, 07:56 AM   #3
Registered User
Termite's Avatar
Bolting is not necessary, and won't really gain you anything with just two plies of wood. You can use 16d nails. I'd do two (or even three) horizontal rows of nails at about 12" apart, staggered, through the 2x10 into the 4x10. Construction adhesive (like liquid nails or subfloor adhesive) would be a good idea.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
