Sistering To A Sagged Rafter - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-04-2012, 03:05 PM   #1
Rewards Points: 252
Sistering to a sagged rafter
I am putting a dormer on my 1.5 story house, and am at the point where I have to sister the rafters on each side of the opening. The house is over 100 years old, so there is about 1" of sag in the middle of the 14' rafters (not bad considering!)
What is the easiest way of dealing with this? The rafters are true 2x6 so could I take a 2x8 and scribe it to fit the curve? Jacking it straight wouldn't be an option as the sag probably happened before the ceiling / rafter ties were installed (probably about 70 years ago). Any help would be appreciated!
shazapple is offline   Reply With Quote
Old 10-04-2012, 04:19 PM   #2
Rewards Points: 2,210
Why not sister and straighten all rafters that are in this area?
I guess scribing a 2x8 would work.
Do you have a permit or need one? that may effect what you can do. ask your inspector if applicable. Notice your in Atlantic Canada. My wife is a Newfie.
mae-ling is offline   Reply With Quote
Old 10-04-2012, 09:48 PM   #3
AHH, SPANS!!!
Rewards Points: 1,166
In situations where ripping the width of the framing lumber will not compromise the strength of the lumber- I will measure the width that needs to come out at the center of the piece and pop a chalk line from center outward to both ends of the piece, making a long V cut .
Also, with the crown of the piece of lumber facing down it will form more (sister) to a sagging framing member though I think there is more deflection strength with the crown facing upward.
Just buy lumber with a 1" crown in it, not hard to find these days
hand drive is offline   Reply With Quote
Old 10-04-2012, 11:12 PM   #4
Amen
Old 10-06-2012, 11:07 PM   #5
Registered User
Rewards Points: 5,236
I doubt your 2x6 roof framing would meet your required energy code for insulation thickness... never rip a piece of lumber to compensate for ?, fig. #3: http://books.google.com/books?id=iwS...joists&f=false why not frame it larger and furr down the rest of the rafters to match?
Gary
Fascia board install - unlevel rafter tails giperbolic Roofing/Siding 3 01-18-2012 12:46 AM
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 11:26 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 08:55 PM
Rotted Lookout Beam Supporting Barge Rafter rwbil Building & Construction 1 08-15-2010 12:40 PM
Sistering rafter acceptable bluefitness Building & Construction 3 12-19-2008 06:59 PM
