Sistering Rafter Acceptable - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-18-2008, 07:39 PM   #1
Rewards Points: 260
Sistering rafter acceptable
The end of one of my rafters is damaged. It has a birds mouth cut at the top plate. I am getting some work inspected in the same area, so I was wondering if sistering the rafter is acceptable by code. I was planning on making the same birds mouth cut and using lag bolts and 16d commons to attach it.
bluefitness is offline   Reply With Quote
Old 12-18-2008, 09:58 PM   #2
I would prefer to use carriage bolts rather than lag screws. Just my opinion!
Old 12-18-2008, 10:05 PM   #3
Registered User
Termite's Avatar
Bolting is completely unnecessary. Use 10's or 16's and use a lot of them and it will be fine. Many engineers also suggest/require construction adhesive. If the existing rafter is damaged enough to require sistering, the sistered member should be full length bearing to bearing. Shorter scabs would require an engineer's report. The code makes no mention of sistering, but it is nearly always an accepted repair.
For what its worth, if this is an existing condition that is not part of the currently permitted scope of work then the inspector has no realistic reason to require you to make repairs. Doing so would be pretty unfair. Of course it is a good idea to fix it though.
Old 12-19-2008, 06:59 PM   #4
I dont see why you cant sister it if its damaged the repair it ... I usually put 4 nails every 16" to 20" down the member on both sides
kevin211mvd is offline   Reply With Quote
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 07:03 PM
insulating 2x6 rafter bays- not enough room! roadk Building & Construction 6 09-29-2008 08:32 AM
need some rafter help feralfreak Carpentry 5 07-30-2008 07:48 AM
rafter questions - structural rtoni Carpentry 11 09-13-2007 06:40 AM
