Old 05-03-2007, 04:58 PM   #1
Default sistering joists
i have a full loft above my 20x24' garage. the 1/2" plywood floor is laid on 2x7x20' joists. the span is 16" oc. to what degree would sisterig with 2x12x20's help eliminate the deflection i now have?
tdelc is offline   Reply With Quote
Old 05-03-2007, 05:34 PM   #2
I'd like to know where you get 20' lengths from, no way that's what you have and even 20' 2x12s won't give you enough strength in the flex area to do anything with, you need to shorten the unsupported span, or you probably already have strips of wood in the middle of that span up to the roof rafters holding it all up, that's what they did in my garage, I have a 22' unsupported span, but they aren't one piece, they double up in the middle.
R&D Tile is offline   Reply With Quote
Old 05-03-2007, 05:34 PM   #3
Tileman-Manufacturers rep
It would make a tremendous difference. Adding 2x12 Southern Pine in #1 or select structural grade would be adaquete by themselves. Sistering to the 2x8 you now have (1.5x7.25) would be great. But the ends would need to be supported too. If it were me I would sister with the same size you now have making it a much easier job.
Double check the thickness of the plywood subfloor, hopefully its 5/8 and not 1/2". All Plywood measures 1/32" under the stated thickness. What do you plan to use the loft for? Oh, the span is 20 ft. not 16".
Jaz
Old 05-03-2007, 08:13 PM   #4
Home Improvement Guy
ron schenker's Avatar
Remember to use construction adhesive when you sister and some bolts and nuts wouldn't hurt either
ron schenker is offline   Reply With Quote
Old 05-05-2007, 08:57 AM   #5
Extreme DIY'r Adk's, NY
[quote=R&D Tile;43410]I'd like to know where you get 20' lengths from, quote]
why? I assume he means 2x8's but I can even get 2x6's in 20' lengths?
crecore is offline   Reply With Quote
More On This Topic
On behalf of expert village, my name is Gregg Tauriello. I'm from suite 16 studio. I'm here to talk to you about soundproofing your recording studio. On this building I have T-111 siding on the outside, which is a standard cardboard siding that you will... Read More »
Here we have 1/32 notes applied to a half time back beat. To form the back beat we'll play the bass drum on one and three, the snare on two and four. Now, let's talk about how we're going to make our hands play 1/32 notes on the high hat and also the... Read More »
Learn how to clean a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Part 1 - Learn how to string a fender stratocaster electric guitar in this diy guitar setup video. Read More »
Learn how to tune a fender stratocaster electric guitar in this diy guitar setup video. Read More »
garage ceiling joists josh123 Carpentry 6 07-15-2009 01:07 AM
sistering 2x6 ceiling joists nelsonC Building & Construction 23 11-21-2008 12:01 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 09:57 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 10:50 PM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 01:16 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
