Sistering A Joist With Plywood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 09:48 PM   #1
sistering a joist with plywood
is there any benefit to sistering a joist with plywood?
artmark is offline   Reply With Quote
Old 11-01-2010, 09:56 PM   #2
Rewards Points: 150
I think if you put 1/2 inch plywood glued and tacked between 2 joists it makes it stronger because its laminated like a header but I don't think just plywood by itself would be very strong. If it's a space issue look into a flitch plate its a piece of steel added to the length of the joist to make it stronger.
guest is offline   Reply With Quote
Old 11-02-2010, 01:28 AM   #3
Rewards Points: 1,092
This came up a while ago, and I mentioned using plywood, "glued, screwed, and tattoed" to a single joist. A reply was "I would never spec plywood; worst wood to use, as every other lam is perpendicular to the load". Since then, I did some looking. Here is one link on the subject, and what I interpret it to say is "If that is all the room you have, then it will help, but a solid piece of wood would be better" because of the lam situation. On the other note, I'd be real careful about putting steel into a header; a floor joist, sure. Steel is way stronger than wood, inch by inch. Art: Did we talk a bit ago on a different thread about the steel straps?
http://www.finehomebuilding.com/how-...-up-beams.aspx
Old 11-02-2010, 09:07 AM   #4
yes I have a dilema I have a built up beam side loaded bolted together there is a wire hole drilled in the no drilling holes range of 2" trying to find a fix other than taking the house apart or praying it never fails
Old 11-02-2010, 12:50 PM   #5
a hole for a wire is typically pretty small. if it is near the top, it is likely not a big deal. if there is concern, employ a couple of the methods suggested and go to sleep. too, if there is room, hang a 2x4 or 6 underneath the problem joist, and tie them together with plates of plywood, 1x8s, or sheet metal.
Old 11-05-2010, 09:23 AM   #6
Thank you, hole is on tension side been there for 12 years I do want to sleep! because of the bolts and the distance from next joist sistering will not work, also no head room what about metal straps does any one have a link?
Old 11-05-2010, 12:42 PM   #7
Article on this subject is in Fine Home Building, Dec 2006/Jan 2007, "Ways to stiffen a bouncy floor", BY MIKE GUERTIN AND DAVID GRANDPRÉ, pgs 90-95. After 12 yrs you are still worried about it? Install the straps; sleep well. j
Old 11-05-2010, 08:26 PM   #8
J thank you but does not things like this get worse over time?
Old 11-05-2010, 09:19 PM   #9
Civil Engineer
Rewards Points: 4,854
Go back to sleep. Relax. If the joist has held up 12 years, you are OK unless you change the load on the joist. Unless you go beyond the elastic limit on wood, a constant load does not do long term damage to wood.
Old 11-05-2010, 09:22 PM   #10
Thanks Guys maybe some brandy tonight if you were near by I would invite you over
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
question about joist sistering Tonglebeak Building & Construction 9 09-11-2010 11:04 AM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
How to repair floor joist when sistering is not an option jmagee3d General DIY Discussions 2 06-05-2009 02:33 PM
