Sistering Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-14-2007, 07:51 PM   #1
jelly's Avatar
Rewards Points: 330
I need to reinforce a weak floor joist but there is a wire running though it. Normally I would unhook it but it runs into some tight spots.
Since it is only two inches from the end of the joist, can I simply notch out a two inch piece from the end of the new joist?
thanks
jelly is offline   Reply With Quote
Old 11-14-2007, 10:41 PM   #2
Power Gen/RS Engineer
Rewards Points: 566
Or you could simply de-energize the circuit, cut and remove the cable from the existing joist and then splice it around the newly sistered joist when all is complete. It does not appear from the picture that this would be a problem.
Just one thought.
Good Luck!
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 11-15-2007, 08:15 AM   #3
jelly's Avatar
Rewards Points: 330
I think I understand what you mean but these floor joists are my living room ceiling so I must go through with the wire, not around.
Old 11-15-2007, 12:06 PM   #4
Rewards Points: 1,910
Depends on what you are trying to accomplish. Tell us more details about why you need to reinforce the joist.
sistering 2x6 ceiling joists nelsonC Building & Construction 23 11-21-2008 11:01 AM
sistering joists tdelc Building & Construction 4 05-05-2007 07:57 AM
