Sistering To Correct Warped Joist... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 06:56 PM   #1
Sistering to correct warped joist...
So... I have a joist under my bathroom that is warped for some reason. I guess it's possible that it warped due to moisture but it is not soft at all. I suspect it was just warped prior to installation and they installed it with the crown upside down. Most of the other ones are pretty true and level. The problem is, the floor sags about 3/8" over a 16" span from the good joists to the sagging one. I have some questions about correcting this. I was going to sister a new joist in to correct the sag.
Here are a few questions I have:
1) Should I jack up the existing joist in question before attaching the new joist or leave the existing one in place and knock the new joist in place?
2) What sort of fasteners should I use? I read I need to glue the new joist to the existing with wood glue and fasten every 16" O.C. Should I use nails, screws or bolts?
3) How should I remove the nails protruding through the decking/sheathing that are currently in the way of where the new joist will go? Cut them flush wish a sawzall?? Bend them flush with the underside of the decking?
4) I assume I need to remove my bridging...?
5) There isn't much running with the joists. There are two copper supply lines and some romex. Can I just detach these temporarily while I install the new joist? Maybe have my "assistant" guide them over the lines until I am clear to the foundation?
6) Do I need to go PT or just good ole fashioned kiln dried SYP?
Any other issues I am leaving out?
fprawlings4 is offline   Reply With Quote
Old 03-12-2013, 08:42 PM   #2
Rewards Points: 1,442
Assuming that the original joist is not cracked and has no unusual up and down give to it (it's only warped) you could sister a straight 2x4 to it to establish a straight top edge, and that would be enough.
Use a sledgehammer to separate the subfloor from just the joist in question so to be level and to touch only the sister once that is in place.
I would use 3 inch ordinary nails every six inches, plus glue.
I would snip off the nails protruding down from the subfloor above.
The sister 2x4 can be cut into pieces to fit between the bridging without having to remove the bridging.
AllanJ is online now   Reply With Quote
Old 03-12-2013, 09:04 PM   #3
Rewards Points: 13,260
Long Sawsall metal cutting blade and at least a 2 X 6 is the way I'd go.
No need for pressure treated.
Use constrution adhesive not wood glue.
Help needed with floor joist cut for toilet plumbing lb3gunny Flooring 1 02-26-2011 09:47 AM
Floor Joist Notch trophywalleye Building & Construction 1 02-03-2011 04:49 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
Warped joist reznap2002 Building & Construction 2 08-17-2008 06:02 PM
correct joist size for attic helpless handyman Building & Construction 1 07-06-2006 12:29 AM
