Old 01-21-2012, 10:42 AM   #1
Question
Sister studs allowed on load bearing walls?
Hello,
I am moving a washing machine from my second floor to my first floor (no basement). I need to install a wye on my soil stack for the washer, however; in order to get access to the stack I
need to remove part of a stud that is at the end of a load bearing header.
My question is: once I have installed the wye can i simply repair and sister the stud or does the whole stud need to be replaced?
Genno is offline   Reply With Quote
Old 01-21-2012, 10:44 AM   #2
Got a picture?
Old 01-21-2012, 10:55 AM   #3
Disabled wood vet
titanoman's Avatar
Is the new stud going to be under the header?
titanoman is offline   Reply With Quote
Old 01-21-2012, 10:59 AM   #4
yes, it will be under the header
Old 01-21-2012, 11:04 AM   #5
Military Mom of 4
Snav's Avatar
Try to figure out a different solution first - the stack was not there before the studs. Without a photo I can't be of much help, though.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 01-21-2012, 11:08 AM   #6
I will post a photo soon
Wet Edge on Walls: How Far Per Roller Load? Twister Painting 10 11-23-2011 05:28 AM
Load Bearing Walls hwood71 Building & Construction 4 11-04-2011 03:43 PM
Load Bearing Wall?? crocs1977 Building & Construction 4 12-09-2010 08:26 PM
Sister joist and load bearing wall Daniel048225 Building & Construction 2 09-21-2009 10:33 PM
Moving studs on load bearing wall for HVAC? grouse Building & Construction 1 08-20-2009 03:16 PM
