Sister Joist And Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-21-2009, 09:30 PM   #1
Sister joist and load bearing wall
I have a 15 foot load bearing wall on a single story house that I am wanting to remove. My question is can i install sister joist and a few joist to make it a small truss in the attic and still be able to take out the wall safely. The wall is in the middle of the house and appears that there is just a few electrical wires which is no problem in moving. Also it is a hip roof style construction. Thanks
Daniel048225 is offline   Reply With Quote
Old 09-21-2009, 10:26 PM   #2
Registered User
Rewards Points: 4,924
Not without engineering.
Be safe, Gary
Old 09-21-2009, 10:33 PM   #3
Civil Engineer
Rewards Points: 4,522
If the joists run parallel to the wall, are you certain the wall is load bearing? Your post is very confusing, perhaps you can post a measured diagram showing the framing in the attic and its relationship to the wall. A fifteen foot span would require a designed truss, or a designed beam, in either case you need a good diagram to start with, then some serious engineering.
Daniel Holzman is online now   Reply With Quote
Load bearing wall removal options ikessky Remodeling 2 08-24-2009 04:18 PM
Non load bearing wall and inspection NowItsShowtime Carpentry 8 03-26-2009 04:40 PM
Exterior Load Bearing Wall Parallel to Joists samjack Building & Construction 4 08-02-2008 09:37 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 08:12 AM
