Sister Jointing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-12-2012, 07:24 PM   #1
Sister jointing
Hi when you sister joint a broken beam with the same size wood and 4 ft in each direction from the crack and 3 nails every 12 inches does the beam become stronger? the same as it was before the original beam cracked? or weaker than if I would replace the whole beam
thanks
Monello1 is offline   Reply With Quote
Old 10-12-2012, 09:15 PM   #2
Civil Engineer
Rewards Points: 4,854
If the crack is so severe as to render the original beam essentially failed, then partial sistering (which is what you describe) will restore a portion of the original strength of the beam prior to cracking. If the crack allows the beam to retain some strength, then it would require a careful detailed engineering analysis to answer your question.
Old 10-12-2012, 09:17 PM   #3
Rewards Points: 13,978
If it failed you need to first figure out why.
Sister jointing Monello1 Building & Construction 5 10-10-2012 08:51 PM
Sister Joist - Notch Question pleasedrivefast Building & Construction 8 06-01-2012 07:50 AM
sister wall against old stone foundation - bonding agent? tcook555 Concrete, Stone & Masonry 3 03-16-2012 08:23 PM
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Sister floor joists or build support wall? Bcoleman6 Building & Construction 3 02-21-2008 01:06 PM
