Old 10-07-2012, 03:23 AM   #1
sister joining rafters
HI I joined some rafters together with bolts and thick screws and im wondering if it would hold, does any one have a clue they are 2x10x7 and i attached them to my existing rafters that come out of the house 4ft im extending my room
http://www.flickr.com/photos/88196931@N06/
thanks
Monello1 is offline   Reply With Quote
Old 10-07-2012, 08:38 AM   #2
Civil Engineer
Perhaps you can back up and explain exactly what it is you are hoping to accomplish with the rafters. From the photos it looks like you sistered about a four foot section of new rafter onto the existing rafter on the ends. There must have been a specific reason you did this, the more carefully you explain what you did and why the easier it will be to analyze if your project is likely to be successful.
Old 10-07-2012, 10:55 AM   #3
Do the new rafters go on top of the top plate as well?
Do they have a wall under them on the far side, or are they just cantilevered out?
mae-ling is offline   Reply With Quote
Old 10-07-2012, 02:43 PM   #4
Moderator
If one would click on a picture, 10 total will show the big picture. You only needed (nails) fastening the two rafters side-by-side, per code, not bolts or screws as they bear on a wall there (though you do need solid blocking to prevent rotation). So long as you are not thinking about removing same wall... Remember to cut ventilation notches (or screened holes) in the blocking if using passive roof ventilation. Don't forget the rafter up-lift prevention hardware, and your location would help.
Gary
P.S. Welcome to the forums!
Clothes taking longer to dry?
Insulating unvented attic w/ 2x4 rafters? rion.martin Insulation 4 03-27-2012 05:28 PM
Furring out existing 2x6 rafters kirylm Building & Construction 27 02-13-2012 11:10 PM
Insulating 2x4 attic ceiling rafters help needed tseverson Insulation 2 11-01-2011 08:57 PM
Sister 2x4 rafters and other issues Zedman53 Building & Construction 4 02-07-2011 02:38 PM
checking the rafters joefromcal Carpentry 3 10-01-2010 09:12 AM
