Sister Ceiling Joist With Unistrut? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 11:59 AM   #1
Murdy's Avatar
Rewards Points: 37
Sister ceiling joist with unistrut?
I live in an older home. We are in the middle of a kitchen remodel. A couple of the ceiling joists are damaged and/or sagging a bit. Normally, I'd sister with another 2x6. The problem is that I a radiant heat system installed in the ceiling (the hous is on a slab), so there's no room for another 2x6. Question: Is there some kind of metal product, or something else, that I could use to shore up the wood that would be about the size of unistrut? (It's over about a 14 foot span).
Murdy is offline   Reply With Quote
Old 07-04-2011, 01:22 PM   #2
An engineer can specify a real fix. Steel is a great solution, but I wouldn't rely on unistrut without some calculations.
EricL503 is offline   Reply With Quote
Ceiling joist Redbeard58 Building & Construction 3 07-03-2011 08:09 PM
Bad news - asbestos and a failing ceiling joist system sheslostcontrol General DIY Discussions 17 05-30-2011 11:34 AM
Ceiling Joist Beam RWebb Building & Construction 3 11-22-2010 01:17 PM
Ceiling Joist Worries clayrabbit Building & Construction 11 01-06-2008 05:07 PM
sister a joist Jack Hass Carpentry 7 06-19-2007 05:39 PM
